theamcguy
Posts : 68 Join date : 2010-03-31 Age : 70 Location : Fayetteville, NC
| Subject: Load leveling pump location Fri May 10, 2013 6:50 pm | |
| On a 96 RMW where is the load leveling pump located? Besides the pump what else is needed to make it work? Anyone have a picture of the pump they could post?
| Subject: Re: Load leveling pump location Fri May 10, 2013 7:54 pm | |
| The pump is located behind the front bumper, driver side. I think if you open the hood and look down you can see it.
There is also a level switch, that is mounted in the rear axle area, mounted high. I had one of those fail before.
Nick Danger
| Subject: Re: Load leveling pump location Fri May 10, 2013 8:47 pm | |
| To get at the compressor, you have to remove some plastic inside the front of the driver's wheel well. It's only 5-6 screws. There are some pictures from the factory service manual in this thread. | |
| Subject: Re: Load leveling pump location | |
