 Fuel line sources / Repair options
scoob8000
Fuel line sources / Repair options Empty
PostSubject: Fuel line sources / Repair options   Fuel line sources / Repair options Icon_minitimeThu Aug 29, 2013 6:05 pm
Just a noticed a fuel leak on the 95'. Looks like it's pressure line between the filter and the sending unit.
Looks like its leaking from up inside the wheel well over the axle. (The clip that secures the lines is poped open, and it looks like the line was rubbing on sheet metal).
I can't find the dang lines anywhere, are they even still available?
I'm seeing a lot of repair kits, but I've always been told not to repair those plastic lines.
What are our options here? (We're supposed to be driving the wagon 10 hours to Myrtle here in a week).
PostSubject: Re: Fuel line sources / Repair options   Fuel line sources / Repair options Icon_minitimeThu Aug 29, 2013 7:10 pm
Hey scoob!
Those repair kits work fine. I repaired lines with those kits that I bought at NAPA. They are made for that purpose. Never had any problem.
scoob8000
PostSubject: Re: Fuel line sources / Repair options   Fuel line sources / Repair options Icon_minitimeThu Aug 29, 2013 8:40 pm
silverfox103 wrote:
Hey scoob!
Tom,
Long time no see! I haven't really been around the forums much. Lurking around once in awhile. Smile
Gonna check with our usual shop tomorrow. After crawling around under the car, even if I can find the lines I don't feel like stuggling with the car up on jackstands.
Will check napa in AM too.
Thanks!
PostSubject: Re: Fuel line sources / Repair options   Fuel line sources / Repair options Icon_minitimeThu Aug 29, 2013 10:17 pm
I also repaired lines. All three that connected to my sender on my winter wagon. Used the parts store repair kits, no problems.
PostSubject: Re: Fuel line sources / Repair options   Fuel line sources / Repair options Icon_minitimeFri Aug 30, 2013 8:15 am
when I replaced the fuel pump in morticia, the lines were rotted and I used the repair kits that they had at autozone. Worked fine. :-)
Bull
Bull
PostSubject: Re: Fuel line sources / Repair options   Fuel line sources / Repair options Icon_minitimeFri Aug 30, 2013 11:07 pm
I also repaired plastic fuel lines on an LT1 vehicle using brass barbed fittings in a kit from the local auto store. I found them to be a bit of a PITA to get into the line (tight fit, pushing too hard kinks line) but they were there for two years and never leaked.
PostSubject: Re: Fuel line sources / Repair options   Fuel line sources / Repair options Icon_minitimeSat Aug 31, 2013 7:12 am
Some post on how to do it from other forums. Mtrhead79 and I rebuilt his a few weeks ago. The Male end of the line is the only thing we would not find.
scoob8000
PostSubject: Re: Fuel line sources / Repair options   Fuel line sources / Repair options Icon_minitimeSat Aug 31, 2013 8:16 am
Okay, this puts my mind at ease. Smile
» Is there a way to let the options for sticky notes available on my forum?
» Line Break not working (HTML)
» Double line spacing on enter
» The length of the title for this topic must be ranging between 10 and 255 characters , How could I repair it?
» Horizontally align your profile field options
