| Saweeet Motor. | |
+4phantom 309 Olds Weighty Eight Krzdimond 1993 Roady-man 8 posters |
| Subject: Saweeet Motor. Thu Sep 05, 2013 6:22 pm | |
| I just picked up a 1968 Buick 400 Engine. I think I need to make my Roadmaster Powered by Buick. Off to the rebuilders,.. hopefully this doesn't break me. | |
| Subject: Re: Saweeet Motor. Thu Sep 05, 2013 7:59 pm | |
| If my memory serves..... that is a 350 horse, 440 lb ft HOSS of a big block..... bore that puppy out to the 455 and up the TQ to 510!!!! | |
| Subject: Re: Saweeet Motor. Thu Sep 05, 2013 8:31 pm | |
| They are torque monsters! Putting one in the Roadmaster would be neat, especially if it was modernized with some fuel injection. | |
| Subject: Re: Saweeet Motor. Thu Sep 05, 2013 9:57 pm | |
| I plan on using a MSD EFI unit. Going to be more than the motor. So this may be a 2 year plan. [You must be registered and logged in to see this link.]
Last edited by 1993 Roady-man on Thu Sep 05, 2013 10:04 pm; edited 1 time in total | |
| Subject: Re: Saweeet Motor. Thu Sep 05, 2013 10:02 pm | |
| Is converting to fuel injection "worth it"?
There was nothing wrong with the carb'd version...... just find a local "old guy" to keep it running....
Last edited by Superior Finish on Thu Sep 05, 2013 10:10 pm; edited 2 times in total | |
| Subject: Re: Saweeet Motor. Thu Sep 05, 2013 10:05 pm | |
| Probably not worth it, but dam it would be cool. | |
| Subject: Re: Saweeet Motor. Thu Sep 05, 2013 10:10 pm | |
| adjusting only takes a screwdriver and a glass of water.......
....... I wonder if that big block would mate to a 6 speed rower........ | |
| Subject: Re: Saweeet Motor. Thu Sep 05, 2013 10:24 pm | |
| Subject: Re: Saweeet Motor. Fri Sep 06, 2013 8:56 am | |
| Wish I had the pockets for it. | |
| Subject: Re: Saweeet Motor. Fri Sep 06, 2013 9:31 am | |
| One of my first cars was a '68 Buick Slylark Custom with a 350 and 2-spd Powerglide. I gotta say it was a fast car, even with the junk trans. Buick engines make a lot of power. Very cool!
-Mike | |
| Subject: Re: Saweeet Motor. Fri Sep 06, 2013 9:35 am | |
| - phantom 309 wrote:
- do it right,. MPFI
Yeah! Yeah! Turbocharged, intercooled, fully sequential, port fuel injection. ( Says the guy with the GN and GS400.) | |
| Subject: Re: Saweeet Motor. Fri Sep 06, 2013 12:43 pm | |
| Subject: Re: Saweeet Motor. Fri Sep 06, 2013 11:00 pm | |
| dual quads and a 671 on the top, keep it old skool, lol. Sounds like a fun build.
I'm half ass shopping for an Olds 455 for the 91. If one lands in my lap, time for gold paint baby! | |
| Subject: Re: Saweeet Motor. Sun Sep 08, 2013 1:45 pm | |
| Nice Sprocket. Once I'm done my wagon will no longer be a daily driver. | |
JBLTZ
Posts : 39 Join date : 2013-06-19
| Subject: Re: Saweeet Motor. Thu Feb 13, 2014 12:25 pm | |
| So did you do this swap yet? I have thought about doing a 400 many times but then I started reading articles like this. [You must be registered and logged in to see this link.]This would cost a little more but the future potential of the engine is greatly increased. For instance... I want to start out with a LQ4/6.0 van engine that has modern heads.... using a carb conversion will allow using the stock 4l60/700r4 trans that is already in the car and the stock CV throttle cable with very little modification. The real expense is the Carb, Intake and engine mounts... which will be about $1000 but after that... the car is set for the future. Little by little things can be added... things like LSx fuel injection and a 4L80e trans comes to mind... 243/799 heads, a cam and a tune would get that engine closer to 400hp/500lb-ft... which is more then that 400 can reach safely. | |
| Subject: Re: Saweeet Motor. Thu Feb 13, 2014 2:13 pm | |
| - 81X11 wrote:
- One of my first cars was a '68 Buick Slylark Custom with a 350 and 2-spd Powerglide. I gotta say it was a fast car, even with the junk trans. Buick engines make a lot of power. Very cool!
-Mike Nothing wrong with that old powerglide,still being used in 2000 HP dragcars.Buick,Olds and Pontiac from that era were all torque monsters,you felt it in your backbone when the gas was stomped.That was the easiest way to get those heavy cars moving fast back then. |
| Subject: Re: Saweeet Motor. Thu Feb 13, 2014 2:51 pm | |
| The MSD FI is very nice I plan on using it on an upcoming project. jeff | |
| Subject: Re: Saweeet Motor. | |
| Saweeet Motor. | |
