Boomhauers_93Wagon
Posts : 92 Join date : 2012-03-07 Age : 36 Location : Pittsburgh, PA
| Subject: Oil cooler leak... Thu Nov 21, 2013 6:57 pm | |
| Welp I came out to warm my wagon up, the low oil light came on I moved it to find a nice puddle underneath her...I've already changed the oil cooler gaskets I even used rtv...
I don't what I could of did wrong or what could of went wrong already...
I did notice the metal o-rings the go into the cooler looked ok but the rubber looked a little worn...
Is this a big problem with these LT1's?
By the way its my new 96' RMW LT1... | |
| Subject: Re: Oil cooler leak... Thu Nov 21, 2013 9:44 pm | |
| - Boomhauers_93Wagon wrote:
- Welp I came out to warm my wagon up, the low oil light came on I moved it to find a nice puddle underneath her...I've already changed the oil cooler gaskets I even used rtv...
By the way its my new 96' RMW LT1... try this [You must be registered and logged in to see this link.] | |
Boomhauers_93Wagon
| Subject: Re: Oil cooler leak... Sat Nov 23, 2013 7:07 pm | |
| Well played sir lol... thanks alot, the hell with that aftermarket P.O.S. gasket!
Now issue is what could I get in there clean up the old old gasket? I thought I cleaned it a whole hell of alot better then I did... | |
| Subject: Re: Oil cooler leak... Sun Nov 24, 2013 4:57 pm | |
| I got in there ok with a razor blade, make sure its spotless. | |
Boomhauers_93Wagon
| Subject: Re: Oil cooler leak... Sun Nov 24, 2013 7:19 pm | |
| Welp, I hope I did it right this time... I got a long old strightedged screw grinded it down razor thin, got it all out cleaned it up, used the gm gaskets and rtv...
I reinstalled everthing, I'm hoping it will cure with this love Pittsburgh weather I'll finish it up tomorrow... | |
| Subject: Re: Oil cooler leak... | |
