bdubsee
Posts : 30 Join date : 2011-01-10 Age : 50 Location : Orlando, FL
| Subject: Holiday Project: Rebuild the Front Suspension Sun Dec 22, 2013 5:43 pm | |
| At 211k miles, Gilbert's front suspension is all used up. Here's the parts list for my big project for the next week:
- Control Arm Shaft
- Control Arm Bushing - Upper
- Upper Ball Joint
- Control Arm Bushing - Lower
- Lower Ball Joint
- Coil Spring Insulator
- Stabilizer Bar Link
- Tie Rod End - Outer
- Tie Rod End - Inner
- Center Link
- Damper
- Idler Arm
- Stabilizer Bar Bushing
As a bonus, I get to replace the left rear shock that blew on first contact with the ground. If you're counting, I've now installed 3 KYBs on the rear. One has been good, the other two blown. Hopefully the fourth one will be the end of the shock project. | |
| Subject: Re: Holiday Project: Rebuild the Front Suspension Sun Dec 22, 2013 7:41 pm | |
| Brian,you are starting to scare me with your shock problems.Only thing I can think of was that the shocks sat for a long time in the horizontal position and the seals dryed up on the high side.Were the shocks that blew the first 2 you purchased? |
Bull
Posts : 164 Join date : 2013-02-09 Location : MA
| Subject: Re: Holiday Project: Rebuild the Front Suspension Mon Dec 23, 2013 12:00 am | |
| I'll enjoy watching this project. I'd like to go through my front suspension, too, but not this season. | |
| Subject: Re: Holiday Project: Rebuild the Front Suspension | |
