| 86 caprice wagon serivce engine soon light and heater | |
bigbluey88
Posts : 252 Join date : 2013-06-16 Age : 37 Location : windsor locks CT
| Subject: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 7:48 am | |
| When I turn the heat on in my caprice wagon I get a bad smell like oil or gas like and the service engine soon light comes on not sure why any help would be great thanks | |
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 7:51 am | |
| Does it run any worse when this happens? | |
j2rossit
Posts : 97 Join date : 2014-01-13 Location : Oshawa On.
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 9:25 am | |
| Does it do it on all temp settings including A/C or just when you switch to heat? | |
bigbluey88
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 9:35 am | |
| Nope doesnt run any worse but when the cars idling the heat slows down a lil when I accelerate it gets more power haven't tried it on ac but on vent heat and front it was the same | |
j2rossit
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 9:53 am | |
| I'm wondering if it's an electrical problem with the blower motor. try unplugging the blower motor and see if it still sets off the check engine light. | |
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 9:57 am | |
bigbluey88
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 10:05 am | |
| What is pm short for again | |
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 10:15 am | |
| P M = Private Messages
Dan scroll up to the top of the page. You will see a menu bar and on the right side, it will say something like "you have 1 new message".....click.
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 10:42 am | |
| Did you pull your code from the computer? It would help to know what it is. Are there any other symptoms? Could you punctuate once in a while so that I know what is a single thought? It is difficult to read without the punctuation. | |
bigbluey88
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 12:15 pm | |
| Thanks tom checked it. No I didn't j can't check the code cars to old don't have the tools. When car is idle heat gets lower and smells a little, when I accelerate gets higher smells a little also. I'm thinking it has to do with the heater core and definitely going to replace the coolant, and add cleaner coolant. | |
bigbluey88
| Subject: Re: 86 caprice wagon serivce engine soon light and heater Tue Jan 14, 2014 2:09 pm | |
| Actually I'm going to flush the system out and try a new thermostat. | |
| Subject: Re: 86 caprice wagon serivce engine soon light and heater | |
