 Drop tank or trap door
sj95rmw
Drop tank or trap door Empty
PostSubject: Drop tank or trap door   Drop tank or trap door Icon_minitimeMon Jan 27, 2014 12:11 am
There's a great sticky here on dropping the tank to replace the fuel pump. I also noticed on the Net that many
people suggest cutting a trap door for a faster fuel pump job.
Opinions on which method is better ?
PostSubject: Re: Drop tank or trap door   Drop tank or trap door Icon_minitimeMon Jan 27, 2014 2:06 am
The only benefit to cutting a trap door is if you do a lot of road trips and want to be able to replace the pump while on the side of the road.
Otherwise I would not bother. You will spend more time cutting the floor and then sealing it back up then you will just dropping the tank.
PostSubject: Re: Drop tank or trap door   Drop tank or trap door Icon_minitimeMon Jan 27, 2014 9:07 am
If you plan on keeping the car for a long time, and suspect that you might have to replace the pump more than twice, making the mod the first time is cost/time effective. Once you have replaced the pump a few times, it is a less effective tradeoff in time and money. You have to get the sheet metal part from a donor car, so availability of parts is another consideration.
PostSubject: Re: Drop tank or trap door   Drop tank or trap door Icon_minitimeMon Jan 27, 2014 10:06 am
There is a write up here someplace that I did, don't have time to look it up now, but will later. Someone may drop in with it.
sj95rmw
PostSubject: Re: Drop tank or trap door   Drop tank or trap door Icon_minitimeMon Jan 27, 2014 11:04 am
I plan on using a quality wallbro pump & I doubt I'll put more than 100K miles on it
so probably 1st & last time.
PostSubject: Re: Drop tank or trap door   Drop tank or trap door Icon_minitimeMon Jan 27, 2014 5:05 pm
Found it: [You must be registered and logged in to see this link.]
sj95rmw
PostSubject: Re: Drop tank or trap door   Drop tank or trap door Icon_minitimeMon Jan 27, 2014 10:23 pm
Good pictures, great write up. Another way to cut is to put a stop collar on a drill bit so the drill
can't penetrate too deep & just drill a series of holes. I might drop the tank anyway just to
check on all the wiring & tubing. Make sure they're in good shape as well.
PostSubject: Re: Drop tank or trap door   Drop tank or trap door Icon_minitimeTue Jan 28, 2014 1:04 am
If I were to cut the floor of my wagon, I would smooth out the shape of the opening. I would also put a set of connectors where I could disconnect the sender unit at the opening. The wiring is trapped between the tank and body so you would not have to fish it through.
Bull
Bull
PostSubject: Re: Drop tank or trap door   Drop tank or trap door Icon_minitimeTue Jan 28, 2014 1:44 am
Dropping the tanks isn't all that bad, and it does give you the opportunity to clean and inspect some stuff.
» Halloween Font Added To The Font Drop Down Menu In The Forum?
» "Log in" box drop-down from Toolbar.
» drop down navbar - -PunBB
» Drop down menu
» Drop-down menu fails to display in Mozilla Firefox
