 timing set replacement issue
benn
benn
timing set replacement issue  Empty
PostSubject: timing set replacement issue    timing set replacement issue  Icon_minitimeSun Mar 02, 2014 5:25 pm
the original timing chain on my '92 roadmaster is stretched. i decided to do a cheap upgrade and go with a double roller set and also decided to get a cheap stock lt1 cam to swap while im in there. problem is, the double roller timing chain set i ordered through summit doesnt line up with the bolt holes on my lt1 cam shaft. this is the timing set i bought [You must be registered and logged in to see this link.] i thought any gen. 1 timing set would work... any ideas?
heres the set that is supposedly a direct replacement for my car [You must be registered and logged in to see this link.]
Here's what we're dealing with
benn
benn
PostSubject: Re: timing set replacement issue    timing set replacement issue  Icon_minitimeMon Mar 03, 2014 11:58 am
lol solved it. timing set i ordered was for factory flat tappet motors. didnt know they had a larger bolt spread for the cam
» Paypal Issue
» Vote Bar Replacement Needed
» Avatar File Size Issue
» Members logging in Issue
» Forum domain deletion/email issue
