 Steel Lower radiator tube 94-96 RMW Max cooling
Skier
Steel Lower radiator tube 94-96 RMW Max cooling Empty
PostSubject: Steel Lower radiator tube 94-96 RMW Max cooling   Steel Lower radiator tube 94-96 RMW Max cooling Icon_minitimeWed Sep 10, 2014 10:33 pm
I need the steel tubing that goes between the two rubber lower radiator hoses for the Max cooling on the 94-96 LT-1 engines. I have a 1995 RMW that has the heavy duty tow package. At some point 3-5 years ago I suspect the lower (passenger side) radiator hose was replaced with a DAYCO 71703 hose. This is for the non towing vehicles. It fits and works fine as I can see. The FSM states the steel center section is for protection from the Clutch fan. This Part is not availble from dealerships or aftermarket that I can find. The GM Parts East show a diagrams for the part with number 16 but no description or part number and stating it is not available. If any one knows where I can get one or even has a rusty not usable one to use as a pattern to fabricate a new one please respond.
PostSubject: Re: Steel Lower radiator tube 94-96 RMW Max cooling   Steel Lower radiator tube 94-96 RMW Max cooling Icon_minitimeThu Sep 11, 2014 8:37 am
It would probably be easier to convert to the dual fan system, than to find the metal hose.
PostSubject: Re: Steel Lower radiator tube 94-96 RMW Max cooling   Steel Lower radiator tube 94-96 RMW Max cooling Icon_minitimeThu Sep 11, 2014 9:39 am
PM sent.
I have one.
ayilar likes this post
» Need 1 good steel rim for '96 RMW
» SOLD -NOS Caprice 9C1 Silicone Radiator Hoses -Upper & Lower
» steel wheels
» Steel rims
» more steel for my roadie
