 Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon?
Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon? Empty
PostSubject: Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon?   Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon? Icon_minitimeTue Aug 11, 2015 9:16 am
The metallic strip embedded in the colored side mouldings of my wagon are deteriorated.  The clear plastic outer cover has separated from the metallic layer underneath.  Is there a way to remove the outer plastic layer and underlying metalic layer, and paint the moulding to match the body color?  Or, is there a decent aftermarket moulding available?
Does anyone know of a source for salvaged mouldings that are in decent shape?
What's involved in eliminating all the offending mouldings?  The sides are stick-on, but once you get to the rear corners and across the tailgate, what happens?
Deadmanonduty
PostSubject: Re: Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon?   Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon? Icon_minitimeTue Aug 11, 2015 1:36 pm
I removed mine, I prefer the cleaner look!  The front bumper still has them I think, but its minor!
Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon? IMG_2118_zps412fe1c9
Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon? IMG_2120_zpsf85a1db6
Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon? IMG_2116_zps50d901c1
PostSubject: Re: Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon?   Suggestions on repair/replacement of side mouldigs on 1996 Caprice Wagon? Icon_minitimeWed Aug 12, 2015 7:25 am
Thanks.  Very nice look! My mouldings all have to be removed as step one of any process, so I can just leave them off for a while and see if I like the cleaner look.  I had wanted to keep it as original as possible, right down to the wire spoke wheel covers, but the trim on one side looks a bit daggy.  Odd: the opposite side looks fine.
I'll clean them up and repaint them once they are off the car.  If nothing else, I can take them to the next Wagonfest parts swap.  I need some interior plastic covers for the rear pillars if anyone has them.  Color is Bordello Red, but I could dye any color to match.  Need the drivers-side seatbelt buckle cover too, and the plastic keeper button that prevents the clip from sliding down to the floor when you unbuckle.  Nickle and dime stuff, but necessary.
» 1996 Roadmaster Wagon seatbelt and tailgate handles replacement and roof grab-handle addition
» oem# 94 caprice wagon side view mirrors?
» 1996 Caprice wagon from Colorado
» 1996 DGGM Caprice Wagon, 94k mi.
» 1996 Chevy Caprice Wagon
