| Subject: Time to clean the cellar! Thu Jun 15, 2017 3:47 pm | |
| I have had LAB RMW's for 21 years, sometimes two at a time. Unfortunately with that, comes accumulating stuff. Up until two weeks ago, I have had 2 wagons and a Fleetwood. Now, I have slimmed down to a wagon and a Fleetwood. That's plenty. I knew that if I was going to clean my cellar, the Roadmaster and the baggage that came with it were going to have to go. The wagon is gone, now the baggage:
1. Reese Class III hitch---$200 2. Curt Class II hitch---$40 3. Rear gate window(s) w/defrost (2)---$80 ea 4. Set of steel rims, no rust---$60 5. Roadmaster Speedometer display, 158K---$35 6. Set of 9C1 center caps---$40
7. 96 PCM OB2---$40 8. 94-5 PCM OB1(2.56)---$40
9. 94-5 PCM OB1(2.93)---$40
10. 6 Chevy Astro aftermarket center caps---$30 11. Mid 70’s Caddy wheel covers---$40 12. RMW grill---$80
13. License plate holder, front for wagon---$25
14. Hooks rear door blue, two---$10 for both 15. Spare tire strap---$20
16. Gas pedal assembly---$10 17. Latch for cargo compartment (floor)---$15 18. Plastic cover for seat rails (set of 4)---$5 19. Driverside front door bezels blue (2), grey---$20 each 20. Passenger side front door bezel blue, grey & tan---$20 each 21. Rear wiper arm (2)---$40 22. Cruise control unit---$35 23. Hood latch (hood part only)---$20 24. Spare tire rod, wing nut & washer---$20
25. Fuse box cover
26. Driver side window / door switches---$10
27. Passenger side window / door switches---$10 28. Blue second seat overhead reading lights / hook---$25 for 2 29. Wiper fluid tank for wagon---$25 30. RMW rear window popper and wiper switch---$20 31. Wagon headlights L or R---$35 each 32. Wagon 94-6 middle seat back hardware---$30
Shipping is additional.
This is Part I, more to come. If you don't see it ask, as I may have it.
