| Weird rear window... | |
| Subject: Weird rear window... Mon Mar 20, 2017 1:17 pm | |
| Im at work,and someone came in and said your wagon is making funny noises... I investigate to find the rear window is unlatching every so often. Tried pulling fuse 36,same deal. Anybody got a solution? Thanks in advance,Andy... | |
| Subject: Re: Weird rear window... Mon Mar 20, 2017 1:21 pm | |
| Subject: Re: Weird rear window... Mon Mar 20, 2017 1:28 pm | |
| - Andebe wrote:
- Maybe fuse 11,or 13?
Nope...Hmmmm... | |
YachtDriver
| Subject: Re: Weird rear window... Mon Mar 20, 2017 3:02 pm | |
| I would start with the relay.
Typical ground or wiring troubleshooting.
May also be the "Brain" box for the remotes.
| Subject: Re: Weird rear window... Mon Mar 20, 2017 3:50 pm | |
| Is is raining? One of mine would do it when it was wet out (some short). I did pull the fuse (sorry it was a few years ago don't recall which one) and would put it back in when I wanted to pop the window... | |
| Subject: Re: Weird rear window... Mon Mar 20, 2017 3:51 pm | |
| Subject: Re: Weird rear window... Mon Mar 20, 2017 8:50 pm | |
| It could be the relay in the remote box, or the relay in the convenience center. | |
occ6.6
Posts : 54 Join date : 2016-01-05
| Subject: Re: Weird rear window... Tue Mar 21, 2017 11:22 pm | |
| my old roadmaster would do that every once in a while , it was the push button on the outside of the gate , it would get stuck in just the right spot & the release solenoid would cycle.might be worth checking on yours. | |
| Subject: Re: Weird rear window... Wed Mar 22, 2017 10:10 am | |
| Will check it out,thanks. | |
| Subject: Re: Weird rear window... | |
