 Gear indicator recalibration
Walterf
Gear indicator recalibration Empty
PostSubject: Gear indicator recalibration   Gear indicator recalibration Icon_minitimeMon Oct 14, 2019 5:12 pm
1991 OCC with stock column shifter. Dropped the steering column during radio install. Went back together well but now the gear indicator is one off; Overdrive is showing as neutral and so on through the entire range. Any one know a fix for this?
PostSubject: Re: Gear indicator recalibration   Gear indicator recalibration Icon_minitimeMon Oct 14, 2019 9:15 pm
You must remove the clip on the cable from the rotating part of the column, and move it to where the indicator is aligned with the gear the trans is in. You can do this in park. I suggest that you remove the knee bolster, and the column loop, or you will need very skinny hands to reach the clip.
Walterf
PostSubject: Re: Gear indicator recalibration   Gear indicator recalibration Icon_minitimeThu Oct 17, 2019 1:23 pm
Thanks, Fred. It worked like a charm - once I knew how. Five minute fix.
» 2-3 gear late shift, no 4th gear
» High Beam indicator always on
» no cruise control indicator in cluster ?
» Instrument panel indicator lamps
» Shift indicator wire broken.
