 94 blue RMW driver interoir door panel
goldwolfnhn
94 blue RMW driver interoir door panel Empty
PostSubject: 94 blue RMW driver interoir door panel   94 blue RMW driver interoir door panel Icon_minitimeSun Mar 01, 2020 8:24 pm
any one here have or know where I can find a complete blue drivers door panel, the one in mine had the common crack already when I bought it and was slightly loose, found out when I pulled it off while replacing the window switch that someone else had already had the door off and broke off most of the clip holders on the lower half of the panel, but also the 'wood' trim on the top of the panel is snapped in half and the plastic insert behind that is damaged around one end of the pull handle.
So I was hoping someone here might have the door panel complete with pull handle and the trim on the panel for something I can easily afford.
» 1971 vista blue driver door panel wanted
» Wanted: LAB woody driver door panel for 94 RMW
» Red '94-'96 RM Driver door panel
» Ruby red driver door panel for RMW.
» looking for sail panel for 94 RMW rear driver side door
