Subject: Re: RMW front seat weights Tue Aug 17, 2021 9:49 pm
Fred - no worries, you didn't miss much
silverfox103 likes this post
dmg4 Moderator
Posts : 1114 Join date : 2014-08-13 Age : 69 Location : Geneva, New York
Subject: Re: RMW front seat weights Fri Aug 20, 2021 5:02 am
150lb with 3 bruised ribs (wife hits HARD) and I did it. Go slow, slide, don't lift until you must. Bring big sheets of heavy cardboard. You can do it.
Subject: Re: RMW front seat weights Fri Aug 20, 2021 7:38 pm
We are about the same size, but I have 5 years older than you and a partially torn rotator cuff that should be decent for the lifting as it not above my shoulders. It would be a this winter project so still got time to look closer or get lucky on an interior shop not being booked up a year. If I get the seats out to do the carpet, I probably will take the cover off the driver's on and see if they can do a couple of panel replacements in it faster and less expensively than if they had the whole car. May also be able to have a regular upholstery shop put the panels in as long as they don't have to deal with the seat.
Subject: Re: RMW front seat weights Mon Aug 23, 2021 8:15 am
you have to turn them sideways and turn them as you take them out, it will become very apparent as you do it. They aren't that bad.
If you struggle you can always pull the seat rails off (4 bolts per seat) once you have them unbolted. They are probably at least half the weight of the whole thing).
Subject: Re: RMW front seat weights Mon Aug 23, 2021 8:49 am
Glad to hear you can get to the rail bolts after taking off the floor to reduce weight as I do that on our Express van RV conversion seats which are on pedestals with rotators also, so very heavy to move out.
