 power antennae
1991BlueBertha
power antennae Empty
PostSubject: power antennae   power antennae Icon_minitimeThu Apr 21, 2022 6:26 pm
how hard is it to get to the antennae to replace it? Mine isn't working and I assume going with an aftermarket one would suffice... much cheaper than going with a refurb one... anyone have any experience with one on our cars? I've got an aftermarket radio already so its no big deal on wiring it up or connecting the cable...
PostSubject: Re: power antennae   power antennae Icon_minitimeThu Apr 21, 2022 9:55 pm
You can get parts at; http://www.antennamastsrus.com/GM/Cheverolet/Caprice/Caprice%201991-1996.htm
You must loosen the wheelhouse all the way to the front. Pull the rear out and hold it with a large pry bar to access the antenna. You need a bezel wrench, and a 10mm socket with long extension to get the screw on the fender with the door open. You must wiggle, and twist it to get it out. The antenna must be in the (mostly) down position to remove it. Remove the antenna cable, and disconnect the connector behind the relay bracket.
1991BlueBertha
PostSubject: Re: power antennae   power antennae Icon_minitimeFri Apr 22, 2022 12:19 am
Fred- any tips on an aftermarket replacement ?
PostSubject: Re: power antennae   power antennae Icon_minitimeFri Apr 22, 2022 7:42 am
No on the aftermarket replacements. They do not recess into the fender.
power antennae
» Power Seat Switch and Power Mirror Motor Lube?
» No power again
» No power at all
» Power Tour
» No more power steering???
