 Changed rear gears, now ABS light is on
5 posters
Changed rear gears, now ABS light is on Empty
PostSubject: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeWed Aug 17, 2022 6:51 pm
I changed the rear gears from the stock 2.92 to 3.43. The car is now way more fun, but the ABS light is now on. I have not reprogrammed the PCM to correct the speedometer. Is the vehicle speed sensor involved in this issue?
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeWed Aug 17, 2022 9:08 pm
Did you use the correct reluctor on the pinion shaft?
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 3:17 pm
The shop transferred the old one over to the new part.
The ABS light only comes on after about 1 -2 miles of driving. Turn the car off, and the ABS light is off when you restart. Drive 1-2 miles, and it pops back on.
I've never had my foot actually on the pedal when it happens, but I've been told that I might feel pulsing in the pedal or a hard pedal just as the ABS light comes one. To feel that, I'd need to drive the first two miles riding the brake pedal.
The VSS is cheap enough. I may just fire the parts cannon and see if the problem disappears.
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 4:48 pm
The shop should have used the reluctor designed for the new gear ratio. The old one will not work with the new ratio. The VSS is not the problem, save the parts cannon ammo. I believe the correct one has 20 "teeth" https://www.drivetrainspecialists.com/gm/gm-85-chevy/gm-85-342-abs-reluctor-ring.html
booster
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 4:58 pm
As far as I know, if the ABS computer sees too much speed difference between the rear wheels and the fronts, it will light the lamp and disable the system. You don't lose any braking, but do lose the ABS function if that is important to you. The difference doesn't need to be very large, sometimes even oversized tires in the back will trigger it.
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 5:07 pm
Ooooooo, the guy who did the job was not happy to get that news, but to his credit he is going to take the whole mess apart again to replace that little bugger. I bought the gear (thanks for the URL), and I'll bring the car back to him next week when the gear arrives.
We both learned something.
1991BlueBertha
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 5:50 pm
I found it easier to pull the cluster and pull the ABS bulb on mine. Smile
booster
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 6:17 pm
I removed mine completely, module and all, and put in a rear proportioning valve. The modules are getting to an age when they are failing, it appears, and I never cared for ABS brakes anyway, or the light rear braking in stock vehicles. I don't drive the Buick in the winter so no end swapping issues with more rear brake. Nice to gain the space under the hood.
I did have to remove the bulb, though, also.
Wojtek likes this post
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 7:47 pm
Easier yes, but equired for safety inspection in NY, so that's not an option.
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 7:57 pm
The bulb or the ABS?
1991BlueBertha
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 8:13 pm
They require ABS?? I can see them failing a car if a warning lamp is on, but if its not on..... Smile
Glad i live in the land of the free down here. I don't even have to have mine inspected... too old and its registered as antique so its a 5 year tag
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 8:28 pm
If a car is equipped with ABS, it has to work. Sort of like turn signals, wipers, and a catalytic convertor. It's not a freedom thing.
Fix Until Broke
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeThu Aug 18, 2022 9:44 pm
You could put 17% smaller diameter tires on the front (or 17% taller tires on the back) to match the gear ratio change Smile
Good on the shop that is making it right for you - that's just good customer service.
1991BlueBertha
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeFri Aug 19, 2022 10:27 am
well i got turn signals, wipers and ..... never mind. LOL
Our state law doesn't require different things for different years.... with the exception of two tail and stop lamps... i think it was prior to 1960 they only require one.... ABS isnt a requirement.... just has to have brakes to stop. Emissions testing on the cars less than 25 years old, how ever, would state that all emissions stuff in place at time of manuf would be required.... but not for these old things....
and yes, land of the free. Free from state inspections on antiques LOL
PostSubject: Re: Changed rear gears, now ABS light is on   Changed rear gears, now ABS light is on Icon_minitimeSat Aug 20, 2022 4:59 am
Something like this?
Changed rear gears, now ABS light is on Maxres10
94Woody, Fred Kiehl, Oscar73, Wojtek and Buickman1 like this post
» 94 RMW dash pad in light blue, and rear handle-light covers
» Rear gears?
» New rear gears
» Wheelhop with big power and T56 eating rear end gears
» (Practically) brand new wagon rear axle with 3.08 gears
