 1996 Roadmaster air Valve? Need Help
jwasner2k
1996 Roadmaster air Valve? Need Help Empty
PostSubject: 1996 Roadmaster air Valve? Need Help   1996 Roadmaster air Valve? Need Help Icon_minitimeWed Oct 26, 2022 1:38 pm
Hi, can anyone tell me what this part is or part number. All I can find is DV130. It is called an A.I.R. Deverter Valve. But the DV130 looks different and says it does not fit in my car. So I'm reaching out for help from all of you. Thanks, John1996 Roadmaster air Valve? Need Help Img_8912[url=https://servimg.com/view/20459363/4]1996 Roadmaster air Valve? Need Help Img_8912[url=https://servimg.com/view/20459363/5]1996 Roadmaster air Valve? Need Help Img_8913[url=https://servimg.com/view/20459363/6]1996 Roadmaster air Valve? Need Help Resize11[/url][/url][/url]
Danr63
Danr63
PostSubject: Re: 1996 Roadmaster air Valve? Need Help   1996 Roadmaster air Valve? Need Help Icon_minitimeMon Oct 31, 2022 12:51 pm
There was a campaign in 1996 to reflash the computer so you would not need any of those parts related to the A.I.R system. Both of my roadmaster wagons had this done by the dealer and I removed all that stuff from under the hood. I will try and find the information and post it.
Isurf
Isurf
PostSubject: Re: 1996 Roadmaster air Valve? Need Help   1996 Roadmaster air Valve? Need Help Icon_minitimeFri Nov 25, 2022 2:29 pm
I had a similar valve under the intake stuff, but the larger lines ran straight thru, instead of 90 degrees like yours. There was a smaller line t'd off that, and broke while replacing the water pump. All I know is I found another in a yard on a caprice lt1 that k replaced mine with.
Isurf
Isurf
PostSubject: Re: 1996 Roadmaster air Valve? Need Help   1996 Roadmaster air Valve? Need Help Icon_minitimeWed Nov 30, 2022 7:46 am
I would be interested in anything related to this reflash. Please share if anyone has it.
» 1996 Roadmaster Estate Wagon & 1993 Roadmaster
» My first 1996 Buick Roadmaster Estate Wagon!
» 1996 WB4 Roadmaster Wagon NW FL
» My 1996 Roadmaster Wagon
» 1996 Buick Roadmaster
