| Rear window dropped today....... | |
+8Fred Kiehl phantom 309 mtrhead79 sherlock9c1 Cadet57 jayoldschool lakeffect BigBlackBeaSSt 12 posters |
| Subject: Rear window dropped today....... Fri Sep 03, 2010 7:45 am | |
| I guess I have a project this weekend. One rear window bushing broke. Good excuse to remove rear panels and rust proof those rear doors!!...... | |
| Subject: Re: Rear window dropped today....... Fri Sep 03, 2010 12:44 pm | |
| Take pics Tim. I have the same issue, droopy rear...... window. You can "pioneer" things and make a repair sticky that the rest of us poor schmucks would greatly appreciate.
Dave
( thahnks to the spele che4sker , I speled SCHMUCKS coreecttly) | |
| Subject: Re: Rear window dropped today....... Fri Sep 03, 2010 1:02 pm | |
| I thought someone did a step by step how to on rollers? Easy job. I'm surprised everyone hasn't done at least one by now... | |
| Subject: Re: Rear window dropped today....... Fri Sep 03, 2010 3:03 pm | |
| There was a thread on rollers, but there are no pics. I need to do mine, but can't even get the stupid door panel off | |
| Subject: Re: Rear window dropped today....... Fri Sep 03, 2010 3:11 pm | |
| You need a phillips screwdriver and one of these: Available at any parts store. Here's the complete how-toYou do NOT need to take the metal armrest support off on the front or rear doors to do the fix | |
| Subject: Re: Rear window dropped today....... Fri Sep 03, 2010 4:12 pm | |
| Thanks for the link... many pics included Thanks!
maybe "we" should sticky the link somehow. | |
| Subject: Re: Rear window dropped today....... Fri Sep 03, 2010 5:01 pm | |
| Fred always used a 5-in-1 tool to get the door panels off. Home Depot is having a sale on them for $5 each right now. I got one. | |
| Subject: Re: Rear window dropped today....... Fri Sep 03, 2010 10:31 pm | |
| rms sells a kit with 2 rollers and the door panel clips i think it was 15.00 worked great for me | |
| Subject: Re: Rear window dropped today....... Fri Sep 03, 2010 10:48 pm | |
| i don't remember ronny doing all that stuff in his 2mins 45 secs it took to change them,..
Nick | |
| Subject: Re: Rear window dropped today....... Sat Sep 04, 2010 5:36 pm | |
Last edited by BigBlackBeaSSt on Sun Sep 05, 2010 8:13 am; edited 1 time in total | |
| Subject: Re: Rear window dropped today....... Sat Sep 04, 2010 11:04 pm | |
| Nice arm rest clamps! The foot...not so much | |
| Subject: Re: Rear window dropped today....... Sun Sep 05, 2010 8:10 am | |
| - jayoldschool wrote:
- Nice arm rest clamps! The foot...not so much
I looked long and hard for a good clamp to do this...... NOT!! Binder clips work almost perfectly. Just be careful it can look "lumpy" if do not keep the clamps close together. | |
Posts : 7182 Join date : 2009-11-13 Age : 75 Location : Largo, FL 33774
| Subject: Re: Rear window dropped today....... Sun Sep 05, 2010 9:23 pm | |
| I use package tape to hold the vinyl tight while the glue sets. Wrap it really tight. Any residue can be removed with goof off. You do not get the lumpy look. | |
| Subject: Re: Rear window dropped today....... Mon Sep 06, 2010 8:15 am | |
| - Fred Kiehl wrote:
- I use package tape to hold the vinyl tight while the glue sets. Wrap it really tight. Any residue can be removed with goof off. You do not get the lumpy look.
I thought about using a paint stir stick under the clamps. That would probably give me a better result, but the tape is a good idea | |
| Subject: Re: Rear window dropped today....... Mon Sep 06, 2010 3:44 pm | |
| tim i saw you in wf pics with your sandles, now after seeing your feet i miss those sandles | |
SShiftn6
Posts : 101 Join date : 2009-03-01 Age : 40 Location : Menomonee Falls, WI
| Subject: Re: Rear window dropped today....... Wed Sep 08, 2010 2:58 pm | |
| So does everybody replace both rollers/sliders on the windows when 1 breaks? I've really only seen the "non-b-pillar" sides break, and can't really see how to pop the ball out of the "good" sliders. | |
| Subject: Re: Rear window dropped today....... Wed Sep 08, 2010 6:29 pm | |
| to get the good 1 out just break it with a screw driver they break easy. just get tip in by center hole and twist | |
WagonLover
Posts : 348 Join date : 2010-01-27 Location : N.E PA
| Subject: Re: Rear window dropped today....... Fri Jan 14, 2011 4:40 pm | |
| are the rear rollers the same as the front rollers?.. cause im doin a search and all its commin up on these websites is the front rollers.. | |
| Subject: Re: Rear window dropped today....... Fri Jan 14, 2011 4:55 pm | |
| Yes. The rear rollers are the same. | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 11:29 am | |
| Planning to fix my driver's door window today. It fell forward going down Friday night, right after I detailed the car to the hilt for the car show....grrrr First time I've done this myself...just read the write-ups here and on the ISSF page. I HATE to be taking my driver's side door panel off again...it took so long to find a non-cracked one and if you remember I had to "build" it using SEM, epoxy, and the original upper soft panel. We shall see... It's funny, I know all four of my door panels had been off before I bought the car. There were broken clips and I had to replace the trim around all four interior door handles, they were all broken. I'd hoped the panels had been off to replace the rollers...knock wood have had zero window issues....until Friday night. What grease are you folks using, white lithium? I don't want to use axle grease, think it would gum up. -Mike | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 1:19 pm | |
| Thought the new rules were suppose to limit foot porn? |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 5:13 pm | |
| You must have been really bored today to did that far back....... | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 6:01 pm | |
| - 81X11 wrote:
- Planning to fix my driver's door window today. It fell forward going down Friday night, right after I detailed the car to the hilt for the car show....grrrr
First time I've done this myself...just read the write-ups here and on the ISSF page. I HATE to be taking my driver's side door panel off again...it took so long to find a non-cracked one and if you remember I had to "build" it using SEM, epoxy, and the original upper soft panel. - Quote :
- There are "new-improved" Christmas tree clips that are wise to use, because they break free a lot easier than the original clips, and save breaking the door panels.
We shall see...
What grease are you folks using, white lithium? I don't want to use axle grease, think it would gum up. - Quote :
- Slobber the heaviest grease you have, on both sides of the roller or slider, in each of the three slide channels. Lithium grease works just as well if you have it, because it doesn't run when it gets hot and should still stay put. If you are inside the door for any reason (like putting in stereo speakers) grease up the slides. Even the original sliders will last, if you put some lube in the channels, and you might never have to replace them.
-Mike | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 6:04 pm | |
| Pic of the newer clip. | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 6:06 pm | |
| - jimbeau wrote:
- Pic of the newer clip.
I have not had luck with this style in the upper rear of the front panel. They do not hold. I think the GM or better brands are much better than the crap you get at autozone. | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 6:07 pm | |
| I got some clips from Napa about a year ago that have worked great. Looked similar to those there. |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 6:16 pm | |
| - Stingroo wrote:
- I got some clips from Napa about a year ago that have worked great. Looked similar to those there.
The caprice has very little problems with the clips. the 90* metal piece that the arm wrest screws to makes sure of that. The LT1 Roady panels depend on these clips to totally support the door panel other than the door pull screws and one lower screw in the plastic. | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 6:21 pm | |
| That is quite strange. So what do the OEM clips look like? Are they fatter to fit the holes in the door better? |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 6:28 pm | |
| The originals look like pac-man on the end, and they grip like hell. Some of us (me included) have pulled off the plastic piece on the panel before the clip gave up. | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 10:23 pm | |
| hey tim saw this post and 1st thing i thought not my window | |
| Subject: Re: Rear window dropped today....... Tue Mar 06, 2012 10:27 pm | |
| You did not put the fork of the tool under the fastener. If you put it on top, and pry on the door, the door panel will break. Another way to avoid breaking the door panel is to cut the fasteners with a long razor knife. | |
| Subject: Re: Rear window dropped today....... Wed Mar 07, 2012 8:41 am | |
| For all the write-ups I read here and on the ISSF forum about drilling rivets and cut arm stories , I was nicely surprised at what an easy job this was. The hardest part was carefully taking the door panel off for fear of breaking it. Once in the door, it was obvious what the issue was, sure enough, a sliding bushing was broken. I'm really surprised people drill out the rivets holding the glass to the track. I was able to slide the old bushing over the rivet and slide the new round bushing back on the track, no problem at all. I stopped the window where I had clear access to the rail, and slid the new bushing in the rail's track, and then used a small C-clamp to force the ball into the bushing. It really was a piece of cake. The entire job took 35-mins. While I was in there I caked the upper and lower rail tracks with lithium grease, as well as the scissor mechanism. The window now rockets up and down faster than it ever has before. Oh and remember I mentioned that I'd thought someone had been in the door before I bought the car? Well the broken slider bushing I removed yesterday was white...but I noticed the other bushing that is still fine is reddish in color....hmmm. Fished around in the bottom of the door and look what I found. Yep, been done before! Door panel is back on and everything went together fine. Good deal! -Mike
| Subject: Re: Rear window dropped today....... Wed Mar 07, 2012 9:52 am | |
| - BigBlackBeaSSt wrote:
The caprice has very little problems with the clips. the 90* metal piece that the arm wrest screws to makes sure of that. The LT1 Roady panels depend on these clips to totally support the door panel other than the door pull screws and one lower screw in the plastic. Yep the LT1 Roady door panel attachment is pretty pitiful. It's no wonder they have so many issues with cracking..and creaking...and rattling. The solid cloth and vinyl panels of the older boxy wagons were much better made! | |
| Subject: Re: Rear window dropped today....... Wed Mar 07, 2012 10:24 am | |
| - Fred Kiehl wrote:
- You did not put the fork of the tool under the fastener...
You are correct, sir. | |
| Subject: Re: Rear window dropped today....... | |
