Posts : 56 Join date : 2021-09-29 Location : eatonton, GA
Subject: Roadmaster wagon parts? Thu Feb 08, 2024 2:42 pm
Hello.. would like to find the SRO list for my 92 roadmaster wagon so as to get the paint code, AND.. a source for the stainless and other side moldings.. thanks
if you can read the SPID inside the tailgate it is there. some google-fu and you should be able to find online quickly as there weren't many color options.
all the side moldings are used, no aftermarket. JY, people parting cars, etc.
Posts : 2400 Join date : 2008-12-02 Age : 49 Location : Ocala,FL
the SPID is too faded to read, the 92 is a darker blue than the blue 95.. (maybe i check that in a few mins) thanks for the link 94woody the rear pass door was crushed by a truck trailer hitch, found a replacement door but it is white and at a body repair shop, maybe the shop can find the right paint color.. also i would like to find the small plastic mounting clips as spares for when the original mounting clips break while working on the door(s).. :-) thanks
Clips are the same as the trim, have to find it someplace because nothing is available new.
Any body shop worth using should be able to easily match the paint. The best one have a scanner that does the work for them.
billmorrow
Subject: Re: Roadmaster wagon parts? Fri Feb 09, 2024 1:17 am
there IS this guy: https://www.3gsperformance.com/gallery-3-1 re. that scanner thing, that blue paint is very tricky to match, a local paint store spent 2 hours trying to have their computer scanner match it and finally it had to be matched the old way, by hand.. VERY tricky blue color.. but you're probably right, besides it is a GM color.. should be available over the counter but then 30 years of fade will come into the equation.. :-\ ahhh, its an old car, deserves some patina..
Subject: Re: Roadmaster wagon parts? Fri Feb 09, 2024 2:10 am
Paint codes are in the front of the FSM. It is called Dark Sapphire Blue.
