| Will 5-127 rims with 5.70 backspacing work? | |
| Subject: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 7:18 pm | |
| I have some rims that I know of that are 17" 5-127 with a backspacing of 5.70 - Im wondering if they will fit
Stock backspacing is 4.5 - correct? |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 8:03 pm | |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 8:22 pm | |
| If they are about 9-9.5" inches wide. | |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 8:58 pm | |
| - jayoldschool wrote:
- If they are about 9-9.5" inches wide.
Why is that? Other than thats the width of the stick tires on a RM? |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 9:07 pm | |
| Because if they're 9 or 9.5" wide, and the backspacing is 5.5", it puts the mounting face of the rim in a spot where it should clear the drum brake and not have any issues with the fender lip.
Stock wagon wheels are 7" wide, by the way. |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 9:11 pm | |
| This is a lot harder that I thought! So geeze - I guess I will have to check the tires. |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 9:12 pm | |
| - Stingroo wrote:
- Because if they're 9 or 9.5" wide, and the backspacing is 5.5", it puts the mounting face of the rim in a spot where it should clear the drum brake and not have any issues with the fender lip.
Stock wagon wheels are 7" wide, by the way. What if they are smaller than 9"? |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 9:48 pm | |
| I will defer to the experts. My wheel fitment knowledge is minimum at best.
To give you a LEGITIMATE answer, you would have to provide at least the following:
Diameter Width Bolt Pattern Backspacing Offset (sometimes listed as "ET")
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Thu Jul 19, 2012 10:13 pm | |
| - Stingroo wrote:
- I will defer to the experts. My wheel fitment knowledge is minimum at best.
Ok - I will find out tomorrow and post it. Thanks so much! |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? Sat Jul 28, 2012 9:38 pm | |
| I'm running 15x8 with 4 in backspace and they are TIGHT but fit. Hard corners and they rub the skirt lip. Alot of guys roll the lip up.
Now the stock SS rims are 17x8.5 but I don't know the backspace but they have plenty of room between the lip and the tire. I've seen guys run 9 in wide rims on a wagon as well.
the 15x8s have a ton of room behind them. so if that is 5.7 in back space and 9 inches or less width I would say you are good to go...
Basically, through my empirical study 4 inches of 'frontspace' and you are REALLY tight. | |
| Subject: Re: Will 5-127 rims with 5.70 backspacing work? | |
