 Good place to tap into 12V for gauges?
autoarcheologist
autoarcheologist
Good place to tap into 12V for gauges? Empty
PostSubject: Good place to tap into 12V for gauges?   Good place to tap into 12V for gauges? Icon_minitimeTue Jan 27, 2015 10:03 pm
Hey gang,
I buddy gave me a old tach he had that will work well in the Roady.  I'd like one a little bigger, but this doesn't block anything.  And I can't beat the price.
I figured out where to run the tach wire to the PCM and picked up a pin from Napa.
I already have one 12 gauge wire running from the aux battery post to power our brake controller.  I need another switched 12V source for the tach and other gauges I would like to install,
One thought I had was to up the wire size currently running into the car and put a small 4 spot fuse box up under the dash, use one spot for the brake controller, another for gauges, a third for aux/phone power and fourth for the radio.
But I was wondering if there is an easier  spot in the fusebox to tap into?  I don't need much power for the gauges, not like the brake controller.
I attached a shot of where the gauge will sit.  The other gauges (trans temp, oil pressure and volts) will likely either sit under the ashtray, hidden in the ashtray, or in a bin above the rear view mirror (my preferred spot).
Good place to tap into 12V for gauges? 20150127_124715
Thanks!
http://www.jewelorjalopy.com
PostSubject: Re: Good place to tap into 12V for gauges?   Good place to tap into 12V for gauges? Icon_minitimeWed Jan 28, 2015 10:16 am
Tach looks great where you placed it and I know someone here will know the best wire to use.Dont know if you are a smoker but there is a pod that replaces the ashtray that will hold a couple of gauges.I have a 3 gauge pillar pod for my wagon,just need to decide which gauges to use and then mount them.Already have a NICE vac gauge to use and have always liked how much a vac gauge can tell you with just a quick glance.
autoarcheologist
autoarcheologist
PostSubject: Re: Good place to tap into 12V for gauges?   Good place to tap into 12V for gauges? Icon_minitimeWed Jan 28, 2015 12:01 pm
Not a smoker so happy to give up the ashtray. Honestly I would be happy to tuck away most of the gauges, we really only need them when towing. The rest of the time I'd be happy to keep the cabin a bit less cluttered.
I had thought about gutting the ashtray and moving the cig lighter lower. I already have a 3 way adapter with USB ports plugged into it, I can just hard wire it in.
71novaguy
PostSubject: Re: Good place to tap into 12V for gauges?   Good place to tap into 12V for gauges? Icon_minitimeWed Jan 28, 2015 12:31 pm
Been a while since I installed a tach, but one wire is for illumination, one is ground, one is signal. Is there a 4th? I though the signal tapped into the coil power wire and ran the tach?
Also, that one looks about the right size. Pull that dash out and drill a hole in the top left corner.
autoarcheologist
autoarcheologist
PostSubject: Re: Good place to tap into 12V for gauges?   Good place to tap into 12V for gauges? Icon_minitimeWed Jan 28, 2015 3:30 pm
4th wire is 12v power. I am going to mount it right where it is, there is no good place in the dash to mount it.
redcaddy
redcaddy
PostSubject: Re: Good place to tap into 12V for gauges?   Good place to tap into 12V for gauges? Icon_minitimeWed Jan 28, 2015 5:19 pm
Hey Flashroo, can you call out a source for that screw in pod, for the ashtray replacement? I was searching a while back and couldn't find anything.
Thanks, Paul
» Where Is A Good Place For The WF09 Threads?
» where's good place to order carpet?
» add-on gauges
» Lower two gauges -- fuel/temp both dead
» Adding gauges solutions
