Jimosborn
Posts : 24 Join date : 2018-09-11 Location : San Diego
| Subject: Climate Control unit lights Wed Oct 10, 2018 10:43 am | |
| My Climate control unit decided to stop lighting up the buttons on the left hand side. Are these lights replaceable?
| Subject: Re: Climate Control unit lights Wed Oct 10, 2018 11:56 am | |
| Hi Jim I just had a similar problem with my Climate Control Unit in my Yukon XL. With that unit, bulbs were soldered onto a board. I can solder, but didn't want any issues. So for $29 including shipping back to me, I sent it to here: https://audioxpress.org/Jeff did a great job, now all bulbs work. He is very quick, I Priority mailed it to him in OH, he fixed it and sent back the same day. It might have taken 4 days total. Probably will be a day more each way to CA. Don't know if the RMW is the same (bulbs on board), but I would guess that it is. Tom | |
Jimosborn
| Subject: Re: Climate Control unit lights Wed Oct 10, 2018 10:16 pm | |
| Tom: Thank you for the recommendation. I will contact audioxpress. Nothing like an easy fix.
Jimosborn
| Subject: Re: Climate Control unit lights Thu Oct 18, 2018 10:35 am | |
| Contacted Audioxpress and they do not repair lights in the Climate Control. Turns out the issue was the headlight switch rheostat. When you turn the knob to adjust the brightness there were gaps in the lights for the dash being on. I replaced the Headlight switch and now everything is lit and bright. | |
| Subject: Re: Climate Control unit lights Thu Oct 18, 2018 10:55 am | |
| There's always something to be learned here, thanks Jim.
| Subject: Re: Climate Control unit lights | |
