How to remove stop pins on front door hinges to open wider?
5 posters
Author
Message
Clifton Springs Hauler
Posts : 54 Join date : 2019-12-16 Location : Manchester, NY
Subject: How to remove stop pins on front door hinges to open wider? Mon Dec 16, 2019 9:42 am
I have seen a brief discussion on removing stop pins on the front doors of RMW, but there is not much info on how to do it i.e. # of pins, direction of removal. Anybody have more info. Thanks.
Subject: Re: How to remove stop pins on front door hinges to open wider? Mon Dec 16, 2019 5:34 pm
Hit from bottom with hammer.
Posts : 2442 Join date : 2008-12-02 Age : 49 Location : Ocala,FL
Subject: Re: How to remove stop pins on front door hinges to open wider? Mon Dec 16, 2019 6:26 pm
What Jay said. They come out very easily.
Careful though because these doors swing WIDE without the stop. I've had to apologize more than once over the years.
Subject: Re: How to remove stop pins on front door hinges to open wider? Mon Dec 16, 2019 8:23 pm
The 91-93 doors have a different style of stop on the hinge. It allows the door to open further, but still have a stop. The 94-96 hinges lack the 91-93 stops.
Subject: Re: How to remove stop pins on front door hinges to open wider? Wed Dec 18, 2019 9:18 am
Thank you for the responses. I have the 95 RMW limited. So if I understand correctly there would be nothing to stop the door swing on my car if the pins are removed?
Subject: Re: How to remove stop pins on front door hinges to open wider? Wed Dec 18, 2019 10:10 am
I believe that the hinge only goes to a certain point, then it interferes with the other part of the hinge. That stops the door from opening any further. I do not think the door will open until it damages the bodywork. Many have removed the pins without issue. I do not have a car with the pins, so I have not experimented with their removal. I have examined both, and that is what the differences were.
Subject: Re: How to remove stop pins on front door hinges to open wider? Wed Dec 18, 2019 10:16 am
Alright then, I will give it a shot and report my finding- as soon as it warms up a bit.
thank you.
Subject: Re: How to remove stop pins on front door hinges to open wider? Wed Dec 18, 2019 7:27 pm
No, there is a stop built into the body of the hinge. You can see it if you shine a light in there and look at the mechanism. Two sheetmetal parts will meet eventually.
Subject: Re: How to remove stop pins on front door hinges to open wider? Wed Dec 18, 2019 7:28 pm
They will indeed stop and not damage anything when opening with the pins removed.
Subject: Re: How to remove stop pins on front door hinges to open wider? Tue Dec 24, 2019 1:21 pm
Just knocked out pins on the drivers door. Mine had to be knocked out from the top down, not bottom up.
Oscar73
Posts : 121 Join date : 2019-02-16 Location : Raymond, WA 98577
Subject: Re: How to remove stop pins on front door hinges to open wider? Tue Aug 11, 2020 12:22 am
Now, I've been reading this thread with interest, as I'm a double amputee, who needs the front door to open mush wider than it does. To this end, I removed the stop pin from the upper hinge. No help at all.
Now, there's a pin in the lower hinge. But, as you can see in this photo, almost impossible to get at because of the door detent and spring.
So, just HOW did you get this thing out?
Subject: Re: How to remove stop pins on front door hinges to open wider? Tue Aug 11, 2020 7:21 am
Put a piece of barstock on the top of the pin, and across to a brace. Hit the barstock between the pin and brace.
Subject: Re: How to remove stop pins on front door hinges to open wider? Tue Aug 11, 2020 2:04 pm
What he said^
They normally come out very easily.
Oscar73
Subject: Re: How to remove stop pins on front door hinges to open wider? Tue Aug 11, 2020 3:01 pm
Now to find a piece of barstock in my apartment...LOL!
Actually, thanks for the tip.
Subject: Re: How to remove stop pins on front door hinges to open wider? Tue Aug 11, 2020 6:32 pm
I use a pry bar. Tip on the pin, hammer tap on the shaft. Easy since the pry bar shaft is square.
Subject: Re: How to remove stop pins on front door hinges to open wider? Thu Aug 13, 2020 3:57 pm
If you look at the picture you will see a thin metal "collar" around the pin that rests on the upper side of the lower part of the bracket. Spin that with a flat blade screwdriver until you find the split and spread open with the flat blade, after removing the collar the pin will basically fall out.
Oscar73
Subject: Re: How to remove stop pins on front door hinges to open wider? Fri Aug 14, 2020 12:08 am
I saw that, WOW! Thanks!
Jim Sorenson
Oscar73
Subject: Re: How to remove stop pins on front door hinges to open wider? Sun Aug 30, 2020 11:35 pm
Thanks, everybody! My door now opens enough to roll my wheelchair up close and personal! Maybe now I can get at that fuse panel and see if I can fix that HVAC nonsense.
Andebe likes this post
