 Idle speed and scan results
68JCode
Idle speed and scan results Empty
PostSubject: Idle speed and scan results   Idle speed and scan results Icon_minitimeWed Jan 22, 2020 8:09 am
Good Morning everyone,  I've had a slightly high idle on my '95 Caprice wagon ever since I bought the car a little over a year ago and I now have Scan 94/95 on my laptop so I can actually investigate it using data!
Anyway, based upon the data below, I assume I have a vacuum leak somewhere since the IAC position is at 0, but I would appreciate a second opinion:
ECT:  192
TPS:  0.71V / 0%
IAC Position:  0
Min IAC Position:  10
MAF: 5.62 gm/sec
Target Idle Speed:  662
Engine RPM:  730
Thanks in advance!
Andrew
PostSubject: Re: Idle speed and scan results   Idle speed and scan results Icon_minitimeWed Jan 22, 2020 11:15 am
A fouled throttle body, a stuck PVC valve, or a failed EGR system could be a possibility. Any accessory with a connection to the intake manifold after the throttle body should be plugged one at a time to see the result before suspecting a gasket failure.
There is also a possibility the IAC itself has failed and is not responding to command.
PostSubject: Re: Idle speed and scan results   Idle speed and scan results Icon_minitimeWed Feb 05, 2020 11:18 pm
Yes, likely a vacuum leak with the age of the car. Try replacing vacuum hoses or plugging vacuum ports and see if the idle goes down. Also, what's the MAP value (kPa) while idling? Should be around 35kPa without a vacuum leak.
68JCode
PostSubject: MAP #s   Idle speed and scan results Icon_minitimeTue Feb 11, 2020 1:44 pm
Thanks for the input guys. Looking at my old data, MAP is running 32.86 in gear, and 37.66 in park. I will start digging into the vacuum lines this week. The low IAC #'s make me suspect that it is getting unmetered air from somewhere.
Thanks,
Andrew
» will this fit an LT1? - now with results.
» Which Scan Tool Should I Buy?
» Stock Dyno Results 94 Roadmaster
» Ran A VIN number to get a build sheet. - RESULTS-
» heating up while at hwy speed?
