 Door wood trim
Sherlock128
Sherlock128
Door wood trim Empty
PostSubject: Door wood trim   Door wood trim Icon_minitimeSun Feb 21, 2021 11:09 am
Does anyone have a good solution to reattacing the wood trim piece above the door grab handle?
Sherlock128
Sherlock128
PostSubject: Re: Door wood trim   Door wood trim Icon_minitimeSun Feb 21, 2021 11:11 am
Wojtek
Wojtek
PostSubject: Re: Door wood trim   Door wood trim Icon_minitimeSun Feb 21, 2021 12:36 pm
3M makes a great product that I have used to reattach the rubber trim mouldings on my previous wagon so I'm sure it will work in your application . 3M Super Strength Moulding Tape part # 03614 it's 1/2 inch wide I purchased mine at my auto paint supply store some years back but I have to believe that it's probably available now at a Napa ,Auto Zone etc.
PostSubject: Re: Door wood trim   Door wood trim Icon_minitimeSun Feb 21, 2021 7:32 pm
You can use the panel adhesive for attaching door skins. Be careful with anything liquid, it can run down, and make a mess of your door. Attaching the trim to the vinyl is not strong, and will probably rip the vinyl off of the door. If you can put a screw in from the back side, and use it as a stud to glue to, that may work better by taking the load off of the vinyl. The original pins are heat welded from the back side.
Sherlock128
Sherlock128
PostSubject: Re: Door wood trim   Door wood trim Icon_minitimeThu Feb 25, 2021 11:03 pm
Thanks! I'll give those a try
Door wood trim
» Passenger side wood trim / door trim
» WTB - Pass. Door frnt for 95 or 96 no wood trim
» Repairing wood trim strips on door panel?
» 1986 BUICK LESABRE ESTATE WAGON... PASSENGER SIDE WOOD GRAIN MIDDLE DOOR TRIM PIECE.
