 Drivers door couldn´t be opened by key / have to unlock it from passenger side
BuickRM
Drivers door couldn´t be opened by key / have to unlock it from passenger side Empty
PostSubject: Drivers door couldn´t be opened by key / have to unlock it from passenger side   Drivers door couldn´t be opened by key / have to unlock it from passenger side Icon_minitimeThu Dec 30, 2021 1:09 pm
On my 94 RMW, on drivers side it is hardly or almost impossible to open the door with the key. The key has to be turned all the way very hard, and the angle doesn´t last out to open the door. I´ve lubricated with WD40, then it works softer, but the angle isn´t enough yet to get the door unlocked. So I have to unlock it from the passenger side manually with the push-button inside with the power locking. Is there something worn out at the lock / lock cylinder or does anyone know the issue?
PostSubject: Re: Drivers door couldn´t be opened by key / have to unlock it from passenger side   Drivers door couldn´t be opened by key / have to unlock it from passenger side Icon_minitimeThu Dec 30, 2021 7:35 pm
You could have bent the rod to the lock. You will be removing the door panel to find out what is up.
» 1996 Roadmaster drivers door lock/unlock switch, no longer needed
» WANTED: 77-79 CHEVY CAPRICE CLASSIC WAGON PASSENGER SIDE FRONT DOOR LOWER DOOR MOULDING
» Help finding a drivers side rear door flyaway on my 95 RMW
» 95 roadmaster rust free body- parting it out
» Needed Drivers side interior door panel in BEIGE 96RMW
