 car dies when put in gear
car dies when put in gear Empty
PostSubject: car dies when put in gear   car dies when put in gear Icon_minitimeMon Feb 15, 2010 7:06 am
Just started this morning. Car starts fine, but if it idles for more than a couple of seconds and I put it in gear, it dies. I can restart and put in gear, only if I do it right away. Let it idle for a couple of seconds, and it will die again if I put it in gear.
Any ideas?
PostSubject: Re: car dies when put in gear   car dies when put in gear Icon_minitimeMon Feb 15, 2010 9:35 am
Sounds like a problem with the "idle air motor". Probably not re-acting fast enough.
PostSubject: Re: car dies when put in gear   car dies when put in gear Icon_minitimeMon Feb 15, 2010 1:48 pm
JESUS, MARY and JOSEPH!!! Autozone has them for $100 [You must be registered and logged in to see this image.] That's too much for me to spend "just in case". Is there a way to test it?
Off to the Junkyard for me.
PostSubject: Re: car dies when put in gear   car dies when put in gear Icon_minitimeMon Feb 15, 2010 2:21 pm
i,d check for a vacuum hose cracked/busted first,..egr stuck open ever so slightly,.
94X2
94X2
PostSubject: Re: car dies when put in gear   car dies when put in gear Icon_minitimeMon Feb 15, 2010 3:28 pm
I had the same problem a while back. I took the idle air motor off and sprayed it out good with intake cleaner.Haven't had a problem with it since.
PostSubject: Re: car dies when put in gear   car dies when put in gear Icon_minitimeMon Feb 15, 2010 4:26 pm
HMMMM, I have a can of that around here somewhere. I'll give that a shot.
» Engine Intermittently dies, runs rough then dies.
» '95 RMW dies suddently & intermittent no start
» LT1 Dies While Driving
» Engine rpm waves and dies - why?
» 94 RMW dies as accelerator is applied
