| Brake light won't go on | |
Shnalla
Posts : 45 Join date : 2015-06-04 Location : Lyon, France
| Subject: Brake light won't go on Thu Apr 14, 2016 12:34 pm | |
| Hi,
On my 84 caprice, brake light recently quit working. Bulbs are fine. Emergency flasher, turn signals and lamp works. I guess the brake light switch has a problem. How can check it ?
| Subject: Re: Brake light won't go on Thu Apr 14, 2016 1:33 pm | |
| There is a brake light switch on the brake pedal arm. It's just a make / brake contact switch. Sometimes a little WD40 or similar sprayed on the switch will do the trick or you may have to replace. They are not expensive.
| Subject: Re: Brake light won't go on Thu Apr 14, 2016 7:04 pm | |
| - Shnalla wrote:
- Hi,
It's one of those problems where you need to stick your head under the dash and look at the switch,. you can push it out of its bracket,.it has a plunger, i,m not sure if yours will have a torque converter lockup plug too,..pull the plug off and jump the wires with a paper clip,. if the brake lights come on then you know you have 12v,. if no power check the fuse | |
Shnalla
| Subject: Re: Brake light won't go on Fri Apr 15, 2016 1:55 am | |
| Thanks for your help! To be honest I really hate electrical issues... The brake light switch looks exactly like that (two plugs) Tom, I will try the paper clip trick | |
dmg4 Moderator
| Subject: Re: Brake light won't go on Fri Apr 15, 2016 6:18 am | |
| OK, I'll ask the D'Oh questions...I assume both brake lights are out, not just one side, correct? Do you have a circuit tester? If not, a trip to the local Bauhaus may be in order. A multi-tester (VOM) is not expensive and they are very useful for troubleshooting voltage/continuity issues. Have you tried a new bulb or two? Filament breaks are not always visible to the naked eye. Same goes for faulty fuses. | |
Shnalla
| Subject: Re: Brake light won't go on Fri Apr 15, 2016 7:56 am | |
| - dmg4 wrote:
- OK, I'll ask the D'Oh questions...I assume both brake lights are out, not just one side, correct? Do you have a circuit tester? If not, a trip to the local Bauhaus may be in order. A multi-tester (VOM) is not expensive and they are very useful for troubleshooting voltage/continuity issues. Have you tried a new bulb or two? Filament breaks are not always visible to the naked eye. Same goes for faulty fuses.
Yep, both brake lights are out (did check bulbs & sockets). And yes, I have a circuit tester, I'll re check both bulbs and fuses. Then I'll try brake light switch. | |
Shnalla
| Subject: Re: Brake light won't go on Fri Apr 15, 2016 12:46 pm | |
| I spent some time under the dash and managed to open the brake light switch. It's really a simple mechanical switch. After cleaning every metal brushes inside, it finally works fine! Problem solved! Thank you all for your help | |
| Subject: Re: Brake light won't go on | |
