 Dome Light with Reading Lights
Dome Light with Reading Lights Empty
PostSubject: Dome Light with Reading Lights   Dome Light with Reading Lights Icon_minitimeThu Jul 13, 2017 1:54 pm
Will anyone be willing to tell me the easiest way to wire up a dome light with reading lights on my our 78 Electra Wagon project car? The car has the plain round dome light that comes on when you open the doors. I snagged this optional dome with map lights and now am not sure how to wire this in. I SHOULD have looked at how it was wired in the car I removed it from....
Dome Light with Reading Lights 10400211
Thanks in Advance as always!
PostSubject: Re: Dome Light with Reading Lights   Dome Light with Reading Lights Icon_minitimeThu Jul 13, 2017 2:38 pm
You'll need a wire that is "always hot", or at least hot in ACC or at KEY ON. The difference being with "always hot" will allow use of the light at any time but runs the risk of being left on, and therefore accidentally draining the battery. KEY ON setup, won't drain the battery accidentally, but obviously always requires the key in the ignition.
It will likely also need a wire from the door switches, so when a door opens, the center light goes on.
So you will need at least two wires for the two power sources, door switch and lamps, and a ground. Sometimes the unit can simply grounds to the body when you use a metal screw to mount it into a roof support.
PostSubject: Re: Dome Light with Reading Lights   Dome Light with Reading Lights Icon_minitimeThu Jul 13, 2017 3:05 pm
Well it has the wires there already for the stock plain round dome light. I was planning to re-use those, but I guess I'll have to run a wire for constant power. Dang. Didn't want to risk damaging the headliner..
PostSubject: Re: Dome Light with Reading Lights   Dome Light with Reading Lights Icon_minitimeThu Jul 13, 2017 3:32 pm
You can help the wire along it's path using a really long zip tie, a tape measure or similar thin stiff objert like 14/2 house wire will work.
Tie the wire to the end and ease the zip tie under the headliner. If you have the little courtesy lights above the doors, there is a hole that can help you pass the zip tie through it.
PostSubject: Re: Dome Light with Reading Lights   Dome Light with Reading Lights Icon_minitimeThu Jul 13, 2017 4:46 pm
Do you want to turn the light on with the car turned off? Can you turn the original light on with the ignition off? If you can turn it on with the ignition off, it is already hot at all times, or at least to the switch that turns it on. If the wire is not spliced for any other courtesy lights, you can spice into it along the driver's side under the sill, or behind the kick panel.
If you remove the B pillar trim, and any other roof mounted lights on the driver's side, you should be able to pull the headliner down enough to see enough to slide a wire under it without damaging the headliner.
steel-and-fire
PostSubject: Re: Dome Light with Reading Lights   Dome Light with Reading Lights Icon_minitimeSun Aug 06, 2017 4:59 pm
Just for reference, here is mine in the Electra
Dome Light with Reading Lights 20170810
Dome Light with Reading Lights 20170811
https://www.youtube.com/weltallid123
» Dome lights staying on.............
» rearmost dome/grab handle lights
» Dome light cover needed
» Looking for GM Deluxe Map Dome Light for 1977-90 Olds CC
» Driver side cargo area dome light
GM Longroof Forum :: Longroof Tech :: Boxies and Related Issues-
