| 1996 RMW Shutoff Will Not Start | |
theamcguy
Posts : 68 Join date : 2010-03-31 Age : 70 Location : Fayetteville, NC
| Subject: 1996 RMW Shutoff Will Not Start Sun Apr 07, 2019 4:25 pm | |
| I started my RMW to warm up in my driveway. It had run about 10 min but before leaving it shutoff. Went to restart and the motor spins, then stops. Cycling the key off then back to start the motor will spin for a couple of seconds and then the motor will stop spinning until the key is cycled off then back to start. Any idea where to look? | |
| Subject: Re: 1996 RMW Shutoff Will Not Start Sun Apr 07, 2019 4:46 pm | |
| Test battery first. Voltage, then load test. Confirm that battery connections are clean and tight. Then, remove and test starter. | |
theamcguy
| Subject: Re: 1996 RMW Shutoff Will Not Start Sun Apr 07, 2019 5:54 pm | |
Fix Until Broke
Posts : 251 Join date : 2019-04-05 Location : Southeast Wisconsin
| Subject: Re: 1996 RMW Shutoff Will Not Start Sun Apr 07, 2019 6:21 pm | |
| Does it crank at "normal" speed or is it slow/sluggish?
When it stops cranking, is it a sudden stop like you just let off of the key or does it stop slowly like a dead battery?
Any extra clicking when the key is in the crank position but the engine has stopped turning? | |
theamcguy
| Subject: Re: 1996 RMW Shutoff Will Not Start Mon Apr 08, 2019 6:01 am | |
| Cranks at normal speed then a sudden stop. Yes extra clicking when key is in crank position but engine has stopped turning. | |
Fix Until Broke
| Subject: Re: 1996 RMW Shutoff Will Not Start Mon Apr 08, 2019 8:27 am | |
| I'd start looking into any one of the several anti-theft measures incorporated. I'll see if I can dig up some of the schematics for the starting circuit to lend a hand a bit later this morning. | |
Fix Until Broke
| Subject: Re: 1996 RMW Shutoff Will Not Start Mon Apr 08, 2019 10:00 am | |
| I've got the two schematics, but can't seem to upload them (says they're corrupted or too large, neither are the case that I can see?). And I can't post links until the end of the week because I just signed up.
If you PM me your e-mail address, I'll send them to you.
Assuming the passkey light does not light up on the dash when this happens - the theft deterrent relay in the right kickpanel might be going bad, or the theft deterrent module in the left kickpanel could be doing it as well.
Maybe wiggle the key as you crank it as the resistor in the key sometimes gets flaky, this would (should) turn on the passkey light though.
Is it exactly the same amount of time that it cranks each time or does it vary some? | |
theamcguy
| Subject: Re: 1996 RMW Shutoff Will Not Start Mon Apr 08, 2019 10:36 am | |
| my email is [You must be registered and logged in to see this link.]It is exactly the same amount of time that it cranks it does not vary It sounds like it does 2 revolutions and stops cycle the key two revolutions stops | |
Fix Until Broke
| Subject: Re: 1996 RMW Shutoff Will Not Start Mon Apr 08, 2019 11:02 am | |
Fix Until Broke
| Subject: Re: 1996 RMW Shutoff Will Not Start Thu Apr 18, 2019 1:36 pm | |
| Subject: Re: 1996 RMW Shutoff Will Not Start | |
