Posts : 270 Join date : 2014-10-28 Location : Sun City Center, FL
Subject: Engine skip? Tue Oct 27, 2020 10:21 pm
My wife’s 1995 pristine RMS stock with 110,000 miles has a slight what appears to be a skip with the engine that is intermittent but frequent. Going down the interstate on cruise control there is a barely noticeable momentary loss of power that lasts less than half a second but happens every 20 seconds or so. Other than that it runs great. It also happens when not using cruise. Any help is appreciated.
rcktpwrd
Posts : 544 Join date : 2019-03-06 Age : 49 Location : Raleigh, NC
Subject: Re: Engine skip? Wed Oct 28, 2020 1:49 pm
could be several things... possibly the torque converter locking/unlocking. maybe bad sparkplug(s) or wires or cap and rotor.
Subject: Re: Engine skip? Wed Oct 28, 2020 7:39 pm
Check the water pump coolant temperature sensor harness connector for corrosion. That input is (sadly) not filtered for transients, and an occasional corrosion-related open circuit will tell the PCM that the coolant is at -40F, radically changing fuel and spark, and unlocking the torque converter. If you have an [You must be registered and logged in to see this link.], you can use eehack to datalog and watch the inputs for any goofy transients. That's how I found this issue.
rcktpwrd likes this post
rjathon
Subject: Re: Engine skip? Thu Oct 29, 2020 7:45 am
You guys are wizards! Thank you very much.
sdowney717
Posts : 111 Join date : 2017-01-01
Subject: Re: Engine skip? Thu Oct 29, 2020 7:20 pm
I had the sensor completely suddenly fail once. Car cut out and refused to start, ECM thought it was -40 outside and was flooding the engine. Replaced and started right up. Might be worth keeping a spare. An ohmmeter test will show its bad. AND I think you can UNPLUG the sensor and ECM will default to more normal temps and car will run ok again.
rjathon
Subject: Bingo Sun Nov 01, 2020 10:54 am
I checked the sensor. It was corroded. I unplugged and plugged it several times and sprayed some Amsoil MP on it and the problem resolved. I got a new one from Rockauto and will install it.
Subject: Re: Engine skip? Sun Nov 01, 2020 11:38 am
Many come with a new plug & pigtails too. If you don't replace the plug, be sure to clean the mating plug/terminals very well else the remaining coolant in the plug will give you the same problem again.
sherlock9c1 likes this post
rjathon
Subject: Re: Engine skip? Mon Nov 02, 2020 6:24 pm
I bought the wrong one. Does anyone have a link to the right part on rockauto?
