Subject: under door panel missing its plastic cover Fri Nov 20, 2020 6:32 am
I suppose help keep dust down, is it worth fabricating something or forget about it. Other rear door, has the plastic under the riveted attachment points for the door handle, and I see no evidence of plastic left there as if it was ripped away.
Subject: Re: under door panel missing its plastic cover Fri Nov 20, 2020 7:32 pm
Post a picture, your post makes no sense.
Subject: Re: under door panel missing its plastic cover Fri Nov 20, 2020 11:22 pm
You can buy some sheets of plastic that can be cut to shape and attached to the door.
Subject: Re: under door panel missing its plastic cover Fri Nov 20, 2020 11:24 pm
Makes perfect sense. They are talking about the clear, plastic sheet that covers the door openings that is "under" the door panel.
Andebe likes this post
Subject: Re: under door panel missing its plastic cover Sat Nov 21, 2020 8:26 am
Upon reading it with a prompt, I now understand where the plastic is. Any heavy plastic sheet would work. Most people do not worry about the plastic if it is torn/missing.
