| Seat belt tensioning? | |
Walterf
Posts : 156 Join date : 2019-03-23 Location : Daytona area, Florida
| Subject: Seat belt tensioning? Thu Jan 07, 2021 8:25 pm | |
| Driver's seat belt on 91 OCC does not retract very well. Is there any [easy and safe] way to adjust spring tension? | |
| Subject: Re: Seat belt tensioning? Thu Jan 07, 2021 8:56 pm | |
| No. You grab another belt with a good retractor, colour doesn't matter, and swap your good belt onto the good retractor. Buy the same side. | |
Posts : 479 Join date : 2016-05-24
| Subject: Re: Seat belt tensioning? Fri Jan 08, 2021 5:51 am | |
| ""Driver's seat belt on 91 OCC does not retract very well."
Sometimes this is caused by the belt fraying, so that it does not slip on itself when rolling up. If a part of the belt is "fuzzy" or soft appearing, it might not work any better in a different retractor. | |
Posts : 7185 Join date : 2009-11-13 Age : 75 Location : Largo, FL 33774
| Subject: Re: Seat belt tensioning? Fri Jan 08, 2021 9:34 am | |
| I have a leak that gets my seat belt wet, and it has become stiff. It does not retract well. If your belt is stiff, first fix the leak (it is probably the seal part that clips over the body seam below the top of the B pillar front and or rear). The wash the belt, and put fabric softener on it. | |
Walterf
| Subject: Re: Seat belt tensioning? Fri Jan 08, 2021 1:16 pm | |
| Found a 91 Caprice in my local LKQ. Unfortunately, the belt and tensioner were in worse shape than mine. I'll keep my eyes open for a replacement. Thanks to all for responses. | |
| Subject: Re: Seat belt tensioning? Fri Jan 08, 2021 4:52 pm | |
| What color is your interior? | |
| Subject: Re: Seat belt tensioning? Fri Jan 08, 2021 6:38 pm | |
| Remember, the colour of the replacement belt doesn't matter... all you need is a belt with a good tensioner. | |
| Subject: Re: Seat belt tensioning? Fri Jan 08, 2021 8:26 pm | |
| If he can get a matching belt and tensioner, all the better. | |
Walterf
| Subject: Re: Seat belt tensioning? Sat Jan 09, 2021 7:30 am | |
| Interior is blue. Are the right and left belts and tensioners interchangable? | |
| Subject: Re: Seat belt tensioning? Sat Jan 09, 2021 8:13 am | |
| Considering what your seat belt is designed to do, you might want to look at this: https://www.seatbeltsplus.com/A used belt may have been stressed in a previous collision. This might cause it to fail when you need it most. | |
| Subject: Re: Seat belt tensioning? Sat Jan 09, 2021 9:03 am | |
| - Walterf wrote:
- Interior is blue. Are the right and left belts and tensioners interchangable?
The belts are interchangeable, but the tensioners are not. So you have the coat hanger style upper anchors, or the cast style? | |
Walterf
| Subject: Re: Seat belt tensioning? Sun Jan 10, 2021 9:58 am | |
| The upper anchors have a delta shape without a slot. Very heavy construction.
The Seatbelts plus site does not list the 91 OCC and not sure if universal replacement would bolt in and fit under molded carpet retainer.
I'm not comfortable with replacing the belt on to a different retainer - would rather find a bolt in replacement. Can't seem to visualize why right belt won't work on left side. THX | |
| Subject: Re: Seat belt tensioning? Sun Jan 10, 2021 10:35 am | |
| I have a pair of blue belts with the proper 91 upper anchors. I can supply a left, and right retractor. I would like $90 shipped for both. I may have covers for the anchors as well, but they may not be blue. You can get plastic paint in the correct color to match. If you need bolts, let me know the length, and I will include them for $3 each. | |
Walterf
| Subject: Re: Seat belt tensioning? Thu Jan 14, 2021 12:48 pm | |
| Thanks, Fred. My son was really impressed with your 373 wagon. Hope to see you at the March Wagonfest. | |
| Subject: Re: Seat belt tensioning? Thu Jan 14, 2021 6:08 pm | |
| That is a 454 in my wagon. Maybe he will be more impressed. | |
| Subject: Re: Seat belt tensioning? | |
