Posts : 231 Join date : 2021-01-13 Age : 74 Location : Columbia Station Ohio
Subject: Oil filler cap Tue Sep 07, 2021 1:21 pm
I'm doing some engine compartment clean up and got rid of the home plate set up and ordered a CAI . The oil filler now sticks up and I'd like to remove it ,it just unscrews ,and run a normal cap .Will cap cap from a Camaro or Corvette work or will I have to replace the valve cover because of the way the filler tube attaches to it ?
do different year LT1 equipped cars have different oil caps? as on mine while the neck is threaded the cap is a twist lock so you can't pull the neck off and put the cap directly on the valve cover.
Wojtek likes this post
Wojtek
Unscrewed the tower and the stock cap is larger and does not screw in as goldwolfnhn mentioned above . I can't see GM using a valve cover specific to this application ,looked at LT1 Camaro and Vett caps on Ebay and they don't look like they screw on but I maybe wrong. Planning to go to Pull A Part to look for some stuff I guess I'll add a cap to the list before I order a new one .
Subject: Re: Oil filler cap Fri Sep 10, 2021 9:41 am
On my '94 it just fit right on the valve cover. I have the same issue as you two on my 95 ( my 94 was wrecked and long gone).
That said I just recalled my 94, I swapped the valve covers as the originals were rusty and I got hold of a minty fresh pair, so not sure where they came from. Big help I know, lol. But you are both right ha ha.
Wojtek
Subject: Re: Oil filler cap Sat Sep 25, 2021 10:18 am
94 Woody noticed on your post that you don't have the oil filter cap extension on your car did you change the valve cover or find a cap that works with the stock cover ? I'm in the process of cleaning up my engine compartment and getting rid of the stock air cleaner assembly don't like the look of the extension .
Posts : 2395 Join date : 2008-12-02 Age : 49 Location : Ocala,FL
Subject: Re: Oil filler cap Sat Sep 25, 2021 3:09 pm
Neither. I used the cap that was on the extension. Fits perfectly. Did the same thing on my old 94 as well.
Subject: Re: Oil filler cap Mon Sep 27, 2021 8:12 am
Tried this again and the cap itself is to big to fit the hole so at this point I guess GM made different valve covers ? . I'll be going to the local Pull a Part maybe I'll luck out and find a set of covers I can use I was going to replace the gaskets and repaint them anyway .
JaySS Admin
Subject: Re: Oil filler cap Tue Sep 28, 2021 8:13 am
Sounds like someone has substituted the cap & tower from an S-10 application.
These were one of the few that still used threads in the cover, but had the quarter turn receptacle on top.
It was also a way back in the day to use of the Corvette Mobil 1 cap without changing the factory covers.
You will probably have a hard time finding a set of stamped covers that use a quarter-turn cap.
Usually those are reserved for the cast ones.
Unless you fall across a set cheap, it will be a lot easier to go get a threaded cap and be done with it.
- J
94Woody likes this post
Any parts store should have the correct (screw in ) cap for the valve cover. That particular cap was used on small block chevy engines for decades.
Wojtek
Subject: Re: Oil filler cap Wed Sep 29, 2021 5:51 am
Success ! Went to Pull A Part and found a 93 Caprice and got the valve covers off of it. The oil filler cap is totally different than the one on the wagon it screws in while the one on the wagon is apparently the quarter turn version . A good clean up ,repaint ,new grommets ,gaskets ,cap and stainless allen center bolts and another thing to cross off my to do list .
rcktpwrd likes this post
goldwolfnhn
watch the clearance between the alternator and the valve cover with the non LT1 valve covers, I know there's a place that sells low profile alternators for LT1 cars but I forget the name of the place
Here is a link to the shallow body alternator for LT1 Cars. They are often out of stock. I actually ordered on up a few weeks ago in the event that I decide to change out my valve covers, which I may end up having to due when the new roller rockers are installed. I wish I could find covers that had Buick on them instead of Chevy/Chevrolet. If anyone sees any cool valve covers for Chev small block, let me know. [You must be registered and logged in to see this link.]
