 abs brakes 91 caprice wagon
pontdog@nb.sympatico.ca
abs brakes 91 caprice wagon Empty
PostSubject: abs brakes 91 caprice wagon   abs brakes 91 caprice wagon Icon_minitimeTue Dec 21, 2021 5:28 am
i have searched this whole section and can't find anything about getting rid of the abs .i have to replace the rear brakes and all the lines so if i put a t in the front and a go into the line into the rear directly from the portioning valve.that way i can eliminate all the abs box and take out the bulb.we don't have inspections here like alot of states.i like the old way and that seems to have always worked for me.if i unplug the box is there anything else i should be aware of.i know i still have to bleed the brakes
PostSubject: Re: abs brakes 91 caprice wagon   abs brakes 91 caprice wagon Icon_minitimeTue Dec 21, 2021 9:11 am
You need to put a line directly from the proportioning valve to the rear line, and a T in the line for the front brakes. You can then remove the entire ABS block, and light bulb. The fittings should be either double flare, or bubble flare. The OEM parts are bubble flared. Bubble flared lines will be compatible with the OEM type, and can be easier overall. I make bubble flares by performing the first step of making a double flare, and using them that way. I chose to shorten the lines, and connect them as directly below the proportioning valve as possible. Put some loops in the line to allow for flexing like the OEM lines. The only issue is getting into the limited space available.
PostSubject: Re: abs brakes 91 caprice wagon   abs brakes 91 caprice wagon Icon_minitimeTue Dec 21, 2021 12:28 pm
thanks Fred that's what i thought
» Which brakes for 91 Caprice wagon?
» can i put disk brakes from a 94 caprice on my 95 roadmaster wagon?
» New rear 300mm brakes compatible with 91-96 caprice sedan (tested) and parking brake - successful completed!
» Replace Powemaster Brakes with Regular Brakes
» Caprice sedan doors on Caprice Wagon?
