 Inconsistent Vibration and Noise
Zanethan
Inconsistent Vibration and Noise Empty
PostSubject: Inconsistent Vibration and Noise   Inconsistent Vibration and Noise Icon_minitimeWed May 18, 2022 7:45 pm
I’ve been trying (not very hard though) to track down a noise on the RMM. It’s a inconsistent thud thud thud which can be felt in the floor and stealing somewhat. Largely noticed at highway speeds and most prominent when turning to the left (even just slightly) or braking. I had suspected motor mounts and just replaced those and it’s still there although much improved. It was in an accident, prior to my ownership, resulting in damage to the passenger front area. Im thinking either control arms or sway bar end links at this point. I just replaced all the tie rods and center link as well so I don’t think it’s those.
booster
PostSubject: Re: Inconsistent Vibration and Noise   Inconsistent Vibration and Noise Icon_minitimeWed May 18, 2022 7:56 pm
I had a similar noise in mine for a while but it showed up and lower speeds. I found that the alignment shims had fallen out of the upper control arm on one end which would let it bang.
sherlock9c1 likes this post
» Bad Vibration
» Odd vibration between 50-55 mph?
» Engine vibration
» Ruby vibration
» Vibration that won't go away, damaged axle?
