Subject: Re: Front brakes are smoking... Sat Sep 17, 2022 10:10 am
I think that even with no rear brakes at all, you still would have to do a bunch of heavy stops to have the fronts so hot they smoke, plus it would dive the nose to some degree.
Regardless of what the rear brakes are doing based on what "grabbing" in the rear means, it sounds like you have something sticking on the front causing the pads to drag. Stuck calipers, stuck pistons, bad hoses that hold pressure, non releasing master cylinder, plugged lines, etc can all do that kind of thing.
It would probably be wise to take apart both ends to see what exactly you are dealing with at this point. If the pads have been smoking, they may well be now glazed over and need to replacement and if the rotor is burned it would at least need to be sanded.
Subject: Re: Front brakes are smoking... Sat Sep 17, 2022 12:46 pm
It would probably be wise to take apart both ends to see what exactly you are dealing with at this point. If the pads have been smoking, the may well be now glazed over and need to replacement and if the rotor is burned it would at least need to be sanded.
thats my thoughts too...if the rears "Grab" that means they would be the ones getting hot and overworked.... should lessen the load on the fronts... if they arent working at all, the fronts will get hotter......
more likely than not, if the fronts are smoking, you have a stuck caliper issue.
Boomhauers_93Wagon
Posts : 92 Join date : 2012-03-07 Age : 36 Location : Pittsburgh, PA
Subject: Re: Front brakes are smoking... Sat Sep 17, 2022 1:41 pm
My bad, if you've got a second to ready I'll give yinz the long version.
Once I brought this 94' Caprice Wagon home to PA I have to get it inspected.
All it needed was front pads and a idler arm.
The front definitely got hot and smoked the day I posted this.
It's not nose diving.
The brake fluid is dark.
They claim to of pulled all 4 wheels off and had a look at things.
I wanted a legit full blown inspection to make sure shes top notch.
Subject: Re: Front brakes are smoking... Sat Sep 17, 2022 1:49 pm
if its a one time thing, brake pads do need to be seated... its normal to smell .... but if the pads were worn out and they replaced them, AND they are dragging and locking up, then i'd say you have a caliper problem.
Wojtek likes this post
Boomhauers_93Wagon
Subject: Re: Front brakes are smoking... Sat Sep 24, 2022 12:55 pm
Update:
New brake hoses, new calipers, new shoes, all 4 corners bled, the rotors were also cut.
Went down a hill in my neighborhood and I started smelling and seeing smoke.
I pulled over and everything was hot and smoking again.
Subject: Re: Front brakes are smoking... Sat Sep 24, 2022 1:07 pm
Master cylinder or plugged line.
At home step on the brake and release and watch the master cylinder reservoir for fluid swirling back into the reservoir to see if it is releasing pressure.
If it is releasing step on the brake and release and crack a wheel cylinder bleeder to check for pressure.
If it has pressure at the wheels and not at the master something is plugged or the ABS module is dead would be the most likely.
Wojtek
Posts : 231 Join date : 2021-01-13 Age : 74 Location : Columbia Station Ohio
Subject: Re: Front brakes are smoking... Sat Sep 24, 2022 3:15 pm
To add if your brake fluid is dark the system should be completely flushed till you get clear fluid in the reservoir
Posts : 2397 Join date : 2008-12-02 Age : 49 Location : Ocala,FL
Subject: Re: Front brakes are smoking... Sat Sep 24, 2022 8:50 pm
Went through a similar situation with a dodge pickup my brother put back on the road. It was a bad proportioning valve that was causing the front brakes to hang.
Buickman1
Posts : 161 Join date : 2021-05-15 Age : 53 Location : Ormond Beach Florida
Subject: Re: Front brakes are smoking... Sun Sep 25, 2022 11:06 am
I would have to agree with the other guys, sounds like proportioning valve or ABS module is acting up. Where did you buy the car from, I'm asking because I lived in Pgh. 50 years and know what corossion can do to the break lines (among other things). Check the wiring going to the ABS and make sure it's not the issue.
Boomhauers_93Wagon
Subject: Re: Front brakes are smoking... Mon Sep 26, 2022 1:35 pm
I filled it up and let it flush itself out before I hooked up the new brake hoses up front.
This is the first wagon (of 6) I've ever had these much brake issues with. This wagon came from the south, but picked it up from Indiana.
vivix
Posts : 19 Join date : 2021-06-14 Location : CT
Subject: Re: Front brakes are smoking... Mon Sep 26, 2022 2:55 pm
How full is the MC? I overfilled mine and it slowly locked the fronts as heat built and the fluid had nowhere to go.
Boomhauers_93Wagon
Subject: Re: Front brakes are smoking... Mon Sep 26, 2022 4:00 pm
Right under the fill line.
I'm genuinely curious, does anyone have a video of front calipers moving?
Reason I ask when I was bleeding everything, the fronts didn't seem to move a bunch.
Subject: Re: Front brakes are smoking... Mon Sep 26, 2022 5:26 pm
If you have the pads out, and the piston pushed in, you should be able to easily move the caliper back and forth by hand. They usually rust and lock up on the two angled connections of the caliper to the carrier, preventing the caliper from moving. Very common in this style caliper.
Boomhauers_93Wagon
Subject: Re: Front brakes are smoking... Mon Sep 26, 2022 6:13 pm
Update as of 6:12pm Yinzer time zone...
Both wheel cylinders are wet and have leaked. I am hope this is indeed the issue.
