Posts : 378 Join date : 2018-05-16 Location : Jersey Shore
Subject: Wheel and tire help Sun Jan 07, 2024 4:21 pm
Mrs. is after me to get a set of chrome wheels. I don't want chrome, I'm looking at some 17x8 cast rallys with 4.5" backspace. I really want an easy bolt on without rubs or other clearance issues.
Subject: Re: Wheel and tire help Sun Jan 07, 2024 4:42 pm
1) how well will they fit? 2) will a spare fit in the well? 3) what size tire will come close to the original 15 inch tire diameter?
Thanks! Happy New Year
I have those wheels only in 17X7.5 because I wanted to use the 235-60-17 tires which came in more choices of tire. I got the low metal centers for them which are like the older Corvette centers. That combo is nearly exactly the original 225-75-16 diameter.
They are nice wheels, good quality, fit well, run true. Nothing bad to say about them at all. The low caps are plated steel and snap in tight so don't fall off like the bigger tall, plastic ones.
I tried to host pix but it is totally different than the last time I did it and it now doesn't seem to work, or I have no clue how to do it.
Isurf and ayilar like this post
Subject: Re: Wheel and tire help Sun Jan 07, 2024 6:09 pm
The OEM tires are 28 inches in diameter. You can use up to 235 wide tires if they are 29 inches in diameter without issues. I run 255-50-17, and they are 27 inches in diameter.
You can go at least as wide as 8 inches as long as you stay with the stock offset (+6 mm or 1/4 inch) and spindle. I have 2 inch drop spindles, so I use a half inch more offset (+18) and the rims are within 1/16 inch of the tierod ends. The drop spindles push the wheels out 1/2 inch, and the added offset puts the wheel back in its original position under the wheelhouse.
Subject: Re: Wheel and tire help Mon Jan 08, 2024 5:05 am
Fred Kiehl wrote:
Picks are nice, but what are we supposed to determine from them?
Clearance of some of the rub areas, wheelwell fill, stance, what they look like on a actual car, appearance with the lower center caps?
Isurf likes this post
Isurf
Subject: Re: Wheel and tire help Mon Jan 08, 2024 2:39 pm
I can show Mrs. pics for approval. My car is not lowered, may consider that in the future. If I do, it will probably just be a set of springs.I plan to restore the self leveling with air shocks at some point. That should cover lowering the rear.
Thanks for the help. No decision this week, research first. Next step is looking at available tires. 17's because rear disk would be nice and I have a kit in mind.
Web site states 0 offset. Is that a problem?
Thanks, Tom
Subject: Re: Wheel and tire help Mon Jan 08, 2024 2:51 pm
The air shocks will not lower the rear without shorter springs. They only raise the rear when a heavy load is placed in the car.
Isurf
Subject: Re: Wheel and tire help Mon Jan 08, 2024 3:28 pm
I guess that will be a concern in the future. Thanks for the heads up.
Subject: Re: Wheel and tire help Mon Jan 08, 2024 9:53 pm
Thanks, Tom
Can't say for wider, but for the 235s no problem. I have had them on for about 4 years without issue.
Wojtek likes this post
swell ride charlie
Posts : 8 Join date : 2023-06-10
Subject: Re: Wheel and tire help Sat Jan 20, 2024 3:32 am
I am running the Vision Rally in 5x5. Look great. One wheel was not round and threw its tall cap. Vision replaced it.
