| Rear Cargo leak and solution | |
| Subject: Rear Cargo leak and solution Thu Apr 14, 2011 4:28 pm | |
| The Caprice wagon that I have had for about 8 months is in really good shape, the only problem I had was water in the drivers side rear cargo wheel well. I drilled a drain whole and kept it inside all winter, so there haven't been any problems. Last weekend I decided to get the hose out and see where exactly the leak was. I narrowed it down to the big cargo window, I did not want to mess with that. I also was suspicious of the little "butterfly" window.
I decided this was a job for professional glass guys. I made an appoint with the local glass company to come out and take the window out and reseal. Today was the day. I said to him, how about putting the hose to that window and see where it leaks. He said if you have an air hose we can really test it, I did. He sprayed window cleaner around the window. It looked like white foam. He then went in the cargo area and used the air hose to blow air all around the window--NO LEAKS. I then sprayed the cleaner around the vent window and he put the air to it. BINGO! That's where the leak is. He looked it over, took the handle apart and tightened the screw, hoping this might do it. Well it was a big improvement, but not fixed. He then looked at the seal around the vent. It was kind of hard where it should be plyable. He worked the seal and sprayed silicon on it. That helped but still leaked.
I said to him, "I have owned these wagons since 1997 and I have never opened those windows nor has anyone else". How about sealing them up, as I will never use them. So I had him seal both windows with urethane. In fact I had him do both wagons while he was there. He did a beautiful job, very neat. He masked around the window and then sealed. It looks great, you would never notice it. Two wagons, four windows, $50, no leaks again or windows flying off.
Tom C. | |
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 4:30 pm | |
| Now that's an interesting find.... |
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 4:48 pm | |
| If I go through the touchless car wash, I can watch water coming in around the vent windows. They don't clamp very hard on the gaskets. Maybe I should glue mine down, too. My Caprice sits outside all summer. | |
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 4:54 pm | |
| Wow Tom mark today on the calender as you have met an honest business man who does not mind showing you his tricks of the trade.Now did you watch what and where he sealed up the windows because I want to do mine and have for some time.I have had the OCC for 7 years and only opened the windows probably 5 times total.Now I have a very good reason to go ahead and seal them up. Thank You Jim Gordon |
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 5:57 pm | |
| Jim G.
Actually, the idea to seal them was mine and he did a great job. Easy job, we all can do it. Shut the window. Mask off the window and both sides of the gap. Fill it in with urethane, and smooth out the joint with soapy water. That's it. He did heat up the urethane. He also told me those side windows never leak, poor design with the butterflies.
Jason
Go do it!
Tom C. | |
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 6:32 pm | |
| Glad that you got the leak fixed, makes you feel good doesn't it? I almost danced in the driveway when I stopped mine, lol.
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 8:23 pm | |
| I am going to be doing this shortly to both of my wagons. As much as I like having the option of opening the wing windows I fear the rust issues much more.Kinda wish I had found out about this idea a long time ago.Thanks Tom a bunch! Jim Gordon |
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 8:48 pm | |
| Jim, easy to do and it will probably take 1 1/2 hours for both wagons!
Tom C. | |
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 10:14 pm | |
| Someone used the air hose with the foam on my window, and stripped my tint off. I was not happy. I can see where my windows are leaking, the reveal molding at the top along the body is seperated from the body.
One of the window guys put butyl around the inside of the seam where the window frame meets the body, and it has stopped the water from coming in. I am concerned that it is still getting between the reveal molding and the body, and causing rust. | |
| Subject: Re: Rear Cargo leak and solution Thu Apr 14, 2011 11:34 pm | |
| Hey Tom is the urethane clear/transparent annd called just urethane or something else?I have silicone/werther stripping and about 6 other tubes of junk but I think I am going out and buy new stuff in the morning. Thank You Jim Gordon |
| Subject: Re: Rear Cargo leak and solution Fri Apr 15, 2011 12:01 am | |
| It is black, he did say silicon would work also. The stuff he used is what they use to set in windshields.
| Subject: Re: Rear Cargo leak and solution Fri Apr 15, 2011 12:17 pm | |
| - Fred Kiehl wrote:
- I am concerned that it is still getting between the reveal molding and the body, and causing rust.
A $4 tube of "flowable" silicone will take care of that. Apply it thin enough and you will never notice it. | |
| Subject: Re: Rear Cargo leak and solution Fri Apr 15, 2011 3:45 pm | |
| I considered taping above and on the reveal molding, then spatulaing some black urethane in the crack. | |
| Subject: Re: Rear Cargo leak and solution | |
