| Replaced a fuel pump yesterday........ | |
| Subject: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 9:18 am | |
| Not any real issues, just leery of failure with 190k on the pump. Starts a little slow from time to time. Put a stock Airtex #E3270 in. Bought a wiring harness and new screen of course. Put in all in, rust proofed the underside and straps while it was out, re-installed tank and NOTHING!!!!! Did not run!! Of course I expected this, Murphy follows me around when I work on my car. Pulled it back down, fortunately I was on a lift and was given a transmission jack by a fellow member, thanks!! Old pump ran fine with old harness. Put old harness on new pump and it was fine. Re-installed and she started right up. So thanks to a bad $6 harness I had to do the job twice!!! ARGHHHHHHH!!!!! Seems to have a little more get up, but that happens every time I wax the car too..... | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 9:29 am | |
| What did you do different the second time Tim? Your wagon is starting to like the way you take such good care of her so she threw you a curvre of sorts.Oh and its a HOT ROD whether you want to admit it or not Tim. Take Care Jim Gordon |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 9:37 am | |
| Did you figure out exactly what failed? There are only three wires in that tank, and I'll spot you a hint - the purple wire goes to the sender so it doesn't matter. | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 9:48 am | |
| - BigBlackBeaSSt wrote:
- So thanks to a bad $6 harness I had to do the job twice!!! ARGHHHHHHH!!!!!
The new harness did not work!! | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 10:09 am | |
| Sorry,missed that Tim.Rough nite so not yet at a 100% yet. Jim Gordon |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 10:18 am | |
| How much was the pump? Just want a number in my head for when it finally happens to me. | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 11:06 am | |
| Rock auto has it for $45 ish. Autozone matched the price. The Walbro 255 is the preferred pump. If my car was a hot hod that is the one I would use!!!! Along with a new complete harness from Racetronix....... | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 1:48 pm | |
| Wow is that cheap! The replacement on my 97 S-10 was over $200.
Good to know! | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 2:03 pm | |
| Where was the pump made? The last 2 delco parts I bought from rock auto (accumulator and FP for my Riv) bragged about being made in CHINA. | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 2:16 pm | |
| Mike, specrta has the whole sending unit and pump for $125 at Rock auto. Not sure where it was made.
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 3:53 pm | |
- Mike, specrta has the whole sending unit and pump for $125 at Rock auto. Not sure where it was made.
The Spectra unit does NOT include the pump. | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 4:35 pm | |
| [You must be registered and logged in to see this link.]SPECTRA PREMIUM Part # SP127B1H Includes Fuel Pump, Sender, Float and Strainer Wagon | |
| Subject: Re: Replaced a fuel pump yesterday........ Tue Jun 07, 2011 4:59 pm | |
- [You must be registered and logged in to see this link.]
SPECTRA PREMIUM Part # SP127B1H Includes Fuel Pump, Sender, Float and Strainer Wagon Thats the same exact part # I bought when I did my sending unit and pump in March, it does not include a pump, its an error. | |
| Subject: Re: Replaced a fuel pump yesterday........ | |
