 Door seals and weatherstripping
Door seals and weatherstripping Empty
PostSubject: Door seals and weatherstripping   Door seals and weatherstripping Icon_minitimeSat Aug 06, 2011 4:23 pm
The front door seals on our cars are a two piece sort of deal,.
has anyone changed them out? mine on the black car are getting tatty,.and i,m getting wind noise more than i,d like,.i was looking on fleabay,. but the prices and descriptions are all over the map,.
PostSubject: Re: Door seals and weatherstripping   Door seals and weatherstripping Icon_minitimeSat Aug 06, 2011 5:10 pm
There is the one around the door itself, and the second one along the top of both doors, and down to the windshield. There is also a bottom seal on the door, that is held on by screws under the trim.
I have R&Rd the driver side upper one, and changed the front driver's side door surround...all of them are basically the same. I have an excellent driver's side front seal for sale ($35 shipped), and could probably get the others. I can give you a break on shipping for more than one.
When mounting the seals, the top one goes behind the tubular part of the door surround seal. If you allow it to be on top, it will cause the door seal to leak
PostSubject: Re: Door seals and weatherstripping   Door seals and weatherstripping Icon_minitimeSat Aug 06, 2011 11:32 pm
looks like the hard plastic one that runs down beside the windsheild is "folded" in,. thats causing the wind noise,.
PostSubject: Re: Door seals and weatherstripping   Door seals and weatherstripping Icon_minitimeSun Aug 07, 2011 12:25 am
Are you referring to the windshield reveal molding, or the one that slips over the flange that is spot welded.
» Door Weather Seals
» Wanted - Roadmaster Wagon Lower Door Seals
» Greetings from Savannah GA
» Window seals wipers weatherstripping
» steam tube seals
