| Door Weather Seals | |
WhiteBird
Posts : 113 Join date : 2021-11-27 Age : 79 Location : WEST VIRGINIA EASTERN PANHANDLE
| Subject: Door Weather Seals Sat Aug 19, 2023 7:59 am | |
| Good day one and all. A little help here please. I am replacing the front and rear doors weather seals. After 30 years they have started to deteriorate. Steele Rubber.COM has them for $145.99 a set so one would need two sets to complete the task. But! they do not have what the GM service manual. refers to as the weather strip roof side rail, auxiliary. Said " send us the original and we will try to match it". So, does anyone know of a company who just might have said weather strip? Thankx Cheers, David R PS: The vehicle is a 93 RMW. | |
booster
Posts : 584 Join date : 2020-04-21 Location : Andover, Minnesota
| Subject: Re: Door Weather Seals Sat Aug 19, 2023 8:06 am | |
| From their website for that part. - Quote :
- This is a universal push-on type Door Weatherstrip. Made with flexible steel core. Can be used for the front or rear entry doors. Purchase two (2) sets if needing all four (4) entry door seals for front and rear.
WhiteBird
| Subject: Re: Door Weather Seals Sat Aug 19, 2023 8:22 am | |
| Thankx booster for the reply. any chance that you know where one can get the heavy rubber weather- strip that runs from the front of the front door where it meets the fender to the rear of the rear door along the roof rail? Cheers | |
booster
| Subject: Re: Door Weather Seals Sat Aug 19, 2023 8:24 am | |
WhiteBird
| Subject: Re: Door Weather Seals Sat Aug 19, 2023 8:26 am | |
| Subject: Re: Door Weather Seals Sun Aug 20, 2023 10:07 pm | |
| I can check on my next visit to the junkyard. | |
WhiteBird
| Subject: Re: Door Weather Seals Mon Aug 21, 2023 8:10 am | |
| Thankx Fred. As you already know, those weatherstrips are glued in. don't go out of your way, But if you happen to come across a real decent pair (they are left & right oriented) I am interested. Cheers. | |
| Subject: Re: Door Weather Seals Mon Aug 21, 2023 12:10 pm | |
| They are not glued, they are held on by the friction of the material. | |
WhiteBird
| Subject: Re: Door Weather Seals Mon Aug 21, 2023 7:05 pm | |
| Dear Mr. Fred Kiehl.
Fred, we are talking about the upper roof rail weatherstrips. On my 96 RMW I was checking to see if it it was or was not glued so I pull it away from behind the rear pax door. It was being held in by some sticky substance. I am far from the original owner of this vehicle and there has been a lot done to this vehicle. so, the glue may have been added later. If it's frictioned on? that makes my task EZ-er. THANKX
Cheers,
| Subject: Re: Door Weather Seals Mon Aug 21, 2023 9:30 pm | |
| I probably have a set of them in my stash, but there is a wagon in the local yard right now, and I would like to harvest as much as possible, because they are so few and far between. They charge by the foot, so I do not know the exact price. Probably about $25 each plus shipping. | |
WhiteBird
| Subject: Re: Door Weather Seals Tue Aug 22, 2023 8:21 am | |
| THANKX Fred. I am in no huge hurry, so when y'all roundup a good set just let me know and we'll work something out price wise. We are talking about the (weatherstrip roof rail aux) This is. how it's listed in the GM service manual. My manual has it as #7. Cheers | |
| Subject: Re: Door Weather Seals Tue Aug 22, 2023 12:27 pm | |
| Subject: Re: Door Weather Seals | |
