| Subject: Re: Bought an engine Sun Jun 10, 2012 1:30 am | |
| - jimbeau wrote:
- Sludge isn't fatal.
depends,. if you are below the surface,. nick | |
| Subject: Re: Bought an engine Thu Feb 28, 2013 6:51 am | |
| Well Guys, I've been abroad for a while and coming back, I decided to roll up the sleeves and see what the rest of the engine will bring. Bottom end looks good (only got some phone pictures) [You must be registered and logged in to see this link.]and I got it doing the total 360. As some of you already said, it's amazing what a good spray WD-40, some waterproof paper and some patience can do. Now for the build, I think I'll go for a 0.30 overbore just to be safe. However, I need some advise about piston choice. Currently, there are dished pistons in the block and from the factory, it has a very low CR. If i go for the overbore and put in flat top pistons, the CR will rise, but is that still low enough to use pump gas? Any advise will be very appreciated. Pete | |
