 Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!
jetfire88
jetfire88
Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells! Empty
PostSubject: Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!   Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells! Icon_minitimeSat Jul 28, 2012 4:25 am
Mine went AWOL so I came up with this.
Go to your local Home Cheapo and get 1/2" plastic pipe fittings.
I used 90 and 45 elbows. You can use a 90 and straight tube, the 90 is the important one.
I did not glue them, they were a tight enough fit.
For looks you can paint them black or body color.
No more wet, smelly floors during hot weather.
Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells! OCC-ac-drain-1
PostSubject: Re: Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!   Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells! Icon_minitimeSat Jul 28, 2012 6:50 am
I just used about 18" of some clear plastic hose from Home Depot, opened up the end slightly with a heat gun, and forced it on. Then I ziptied it to the side of the frame rail so it wouldn't dump onto the ABS connector like the stock one does. Been working fine for years.
PostSubject: Re: Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!   Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells! Icon_minitimeSun Aug 05, 2012 9:23 pm
Cool! I like the hard 90degree pipe fitting..then Ill add the plastic tubing. My stock elbow took a dive last weekend.
Thanks!
» Intake hose drain
» Missing hose
» Help identifying missing vacuum hose
» Air Lift 1000 -- hose up or hose down?
» TPS symptoms and cure
