 Intake hose drain
roadmasterBlue
Intake hose drain Empty
PostSubject: Intake hose drain   Intake hose drain Icon_minitimeSun Jan 21, 2024 3:48 pm
My ‘92 OCC (5.7 TBI) has started running a little rough whe n accelerating I noticed the Intake Air Duct Drain Hose has a big hole in it. Could that cause the rough acceleration? I have no idea what the purpose of that thing is but it’s basically disintegrating before my eyes. Appreciate any advice. Thanks
PostSubject: Re: Intake hose drain   Intake hose drain Icon_minitimeSun Jan 21, 2024 6:16 pm
Need picture
roadmasterBlue
PostSubject: Re: Intake hose drain   Intake hose drain Icon_minitimeTue Jan 23, 2024 9:15 pm
I’m not dure what that thinh is called but its in bad shape[You must be registered and logged in to see this link.]
PostSubject: Re: Intake hose drain   Intake hose drain Icon_minitimeTue Jan 23, 2024 9:46 pm
That is the heat riser tube. You should be able to get one at almost any parts store. It has no affect on running of the engine. I would check or change the plug wires and the cap and rotor. Maybe the plugs too.
Buickman1
Buickman1
PostSubject: Re: Intake hose drain   Intake hose drain Icon_minitimeSat Jan 27, 2024 4:32 pm
If you live in cold weather it is supposed to help the engine warm up faster. I removed mine on every car I've owned.
roadmasterBlue
PostSubject: Re: Intake hose drain   Intake hose drain Icon_minitimeSun Jan 28, 2024 7:43 pm
Seems like rough engine is much worse when in overdrive. If i leave it in drive it’s much much better. I only drive the OCC occasionally and it’s always run smooth. Maybe it’s been sitting too much. I’ll start with plug wires. I once had a wire on my roadmaster that insulation was worn and I noticed some arcing in the dark. Changed wires and it’s been great ever since.
Walterf
PostSubject: Re: Intake hose drain   Intake hose drain Icon_minitimeMon Jan 29, 2024 2:06 pm
I had same symptoms and it was the spark plugs. Follow the advice you've received here and let us know. Cheap and easy fixes are the best.
Intake hose drain
» Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!
» Air Lift 1000 -- hose up or hose down?
» How to replace radiator drain petcock??
» Whats the best way to drain the gas tank?
» 94 Roadmaster Estate drain cock won't open
