 Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!
jetfire88
PostSubject: Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!   Sat 28 Jul 2012 - 5:25
Mine went AWOL so I came up with this.
Go to your local Home Cheapo and get 1/2" plastic pipe fittings.
I used 90 and 45 elbows. You can use a 90 and straight tube, the 90 is the important one.
I did not glue them, they were a tight enough fit.
For looks you can paint them black or body color.
No more wet, smelly floors during hot weather.
PostSubject: Re: Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!   Sat 28 Jul 2012 - 7:50
I just used about 18" of some clear plastic hose from Home Depot, opened up the end slightly with a heat gun, and forced it on. Then I ziptied it to the side of the frame rail so it wouldn't dump onto the ABS connector like the stock one does. Been working fine for years.
PostSubject: Re: Cheap cure for '91-96 missing A/C Drain Hose. No more wet footwells!   Sun 5 Aug 2012 - 22:23
Cool! I like the hard 90degree pipe fitting..then Ill add the plastic tubing. My stock elbow took a dive last weekend.
Thanks!
» THE CURE STARTS NOW; ELENA'S CHARITY
» Winifred Joyce missing from Dublin
» Kristi Cornwell -- Missing 8/11/09
» Charles Arlin Henderson missing for 20 years
» Search for man missing off Cork coast
