| oil cooler lines leak at radiator | |
59 wagon man
Posts : 105 Join date : 2011-07-13
| Subject: oil cooler lines leak at radiator Sun Jul 21, 2013 11:20 pm | |
| anyone know where to get new seals for the lines at the rad? | |
| Subject: Re: oil cooler lines leak at radiator Sun Jul 21, 2013 11:23 pm | |
| If I remember correctly, they are flanged fittings, no "seal" to buy. | |
59 wagon man
| Subject: Re: oil cooler lines leak at radiator Mon Jul 22, 2013 9:47 am | |
| these def had a seal on them | |
scoffman
| Subject: Re: oil cooler lines leak at radiator Mon Jul 22, 2013 9:53 am | |
| If they are like the little o-ring seals for the line connection to the oil filter adapter, I got replacements for mine at ACE hardware store. Find a hardware store that sells o-rings and they should have the size you need. | |
| Subject: Re: oil cooler lines leak at radiator Mon Jul 22, 2013 10:31 am | |
| do they leak AT the radiator or where the hard line turns into rubber? The lines that screw into the radiator are flared fittings - no o-ring. Just tighten them until they stop leaking.
If htey leak at the metal -> rubber joint like mine did, cut the crimp off (slice both sides and pry it apart) then use a pair of real hose clamps (get them at NAPA - do NOT use Advance or Autozone stuff), and reclamp. NAPA also carries replacement oil cooler line hose (1/2" I think) rated for 400psi that'll work.
Last edited by sherlock9c1 on Mon Jul 22, 2013 2:28 pm; edited 1 time in total | |
59 wagon man
| Subject: Re: oil cooler lines leak at radiator Mon Jul 22, 2013 1:12 pm | |
| at the radiator . I stopped at harbor freight and got some oring kits. so ill try that and some Teflon tape | |
| Subject: Re: oil cooler lines leak at radiator Mon Jul 22, 2013 2:06 pm | |
| Something isn't right here. I JUST rebuilt my oil cooler lines a month ago so I'm well familiarized with these lines. The hard line has flared ends - no o-rings or teflon tape required. Post up some pics. | |
| Subject: Re: oil cooler lines leak at radiator Mon Jul 22, 2013 2:09 pm | |
| Yeah. I've replaced both of mine as well on a TBI car like you've got - no o-rings or anything here either. |
59 wagon man
| Subject: Re: oil cooler lines leak at radiator Mon Jul 22, 2013 9:40 pm | |
| well without the orings I can watch the oil pour out a 10mm washer did the trick | |
| Subject: Re: oil cooler lines leak at radiator | |
