| Need door latch | |
| Subject: Need door latch Wed Oct 23, 2013 11:08 am | |
| The passengers's side front door latch has broken, and is in need of replacement. If you have one handy, shoot me a PM so I can get under way to fix the damn thing.
Dave | |
DBeaSSt Admin
| Subject: Re: Need door latch Wed Oct 23, 2013 11:38 am | |
| B pillar post or the latch mechanism inside the door? | |
| Subject: Re: Need door latch Wed Oct 23, 2013 11:52 am | |
| Good question Mike. Probably best to answer both. I need the mechanism itself, but by the time the door actually gets opened, the post may be in bad shape as well.
So I'll answer "Both Please" | |
| Subject: Re: Need door latch Wed Oct 23, 2013 6:45 pm | |
| I can get one. It will have the lock motor, unless you do not want it. I do not know how much right now. Shipping should be about $15. | |
| Subject: Re: Need door latch Fri Oct 25, 2013 11:04 am | |
| Thanks Fred. I am not in need of the electrical components or rods, just the actual latching portion that gets bolted to the rear edge of the door panel. I believe thee are three bolts to hold it in place | |
| Subject: Re: Need door latch Fri Oct 25, 2013 12:33 pm | |
| I can't detach the rods without damaging the clips. I can detach the inside latch plate and lock motor from the latch. | |
| Subject: Re: Need door latch Sat Nov 09, 2013 1:21 am | |
| Do you still need the door latch? I have one with the striker. The rods are still on it, and difficult to remove without damaging the rod end clips. | |
| Subject: Re: Need door latch Sat Nov 09, 2013 9:52 am | |
| Thanks for the reminder Fred. I apologize for not getting back to you sooner with an update. One of the other guys has already come though with what I need via PM. Hopefully it gets repaired within the next week.
Thanks again for the kind offer.
Dave
| Subject: Re: Need door latch | |
| Need door latch | |
