big john and the TANK
Posts : 35 Join date : 2013-04-12 Location : Syracuse, NY
| Subject: Remote start problems. Sat Dec 21, 2013 6:00 pm | |
| Does anyone know if a remote start can cause intermittent running problems? Have the Pass key on the Tank and have a remote start installed a while ago. I believe it has the bypass mod with it or it wouldn't work. Every mech I have taken it to cant get it to stall out. I drive it for one day and spit sputter and almost quit. At my wits end on the issue. Any help will be appreciated. | |
| Subject: Re: Remote start problems. Sun Dec 22, 2013 12:52 am | |
| John, have you checked your fuel pump pressure?
| Subject: Re: Remote start problems. Sun Dec 22, 2013 6:38 am | |
| All fluids and pressures check out. I have installed a new fuel pump, (the good one), fuel filter, coil, ICM, plugs, wires, and optispark. No one has had any issues with the pass key after installing a remote start?
| Subject: Re: Remote start problems. Sun Dec 22, 2013 10:24 am | |
| Did it ever work? The resistor installed to bypass the passkey could be the wrong value or have a poor connection. | |
| Subject: Re: Remote start problems. Sun Dec 22, 2013 2:55 pm | |
| It did work for a while but I removed the system and it still cuts out. Found one of the wires for the MAF sensor pulled out. Can the MAF sensor make the car not run right?
| Subject: Re: Remote start problems. Sun Dec 22, 2013 9:53 pm | |
| - big john and the TANK wrote:
- It did work for a while but I removed the system and it still cuts out. Found one of the wires for the MAF sensor pulled out. Can the MAF sensor make the car not run right?
yes,... | |
| Subject: Re: Remote start problems. Sat Dec 28, 2013 11:34 am | |
| I have posted on FB the issues I have been having with the Tank. Check vacuum lines, clogged fuel filter, clogged cat convertor, bad ground, broken wire in harness, bad fuel pump. I still have to run checks on all those items and because of winter it makes it a little tougher.(no garage) Anyone here believe on of these could be my issue? I'm at my wits end and my wife wants me to sell/trade it in. Need some guidance, Thanks. BIG John | |
| Subject: Re: Remote start problems. | |
